STM32单片机驱动LCD1602液晶程序
* STM32VET6开发板实验程序火牛开发板
* 硬件: RS - RW - EN 引脚用10K电阻上拉,CRL 设置为开漏输出
* 硬件: PB0--PB7 数据脚用10K电阻上拉,CRL 设置为开漏输出
#ifndef _LCD1602_H
#define _LCD1602_H
#include "LCD1602.H"
//============================端口位清除寄存器==============================================//
#define LCD1602_RS0 GPIOE->BRR= 0x00000004 //低电平PE.2
#define LCD1602_RW0 GPIOE->BRR= 0x00000010 //低电平PE.4
#define LCD1602_EN0 GPIOE->BRR= 0x00000040 //低电平PE.6
//============================端口位设置/清除寄存器=========================================//
#define LCD1602_RS1 GPIOE->BSRR = 0x00000004 //高电平PE.2
#define LCD1602_RW1 GPIOE->BSRR = 0x00000010 //高电平PE.4
#define LCD1602_EN1 GPIOE->BSRR = 0x00000040 //高电平PE.4
#define DATA_OUT GPIOD->ODR//数据端口 PB0-PB7
//单片机系统时钟在72MHZ下的延时
void Delay_us(unsigned long CountLing)
signed char i;
while(CountLing--)
i = 10;
while(i--);
//LCD1602液晶读忙状态
void LCD_FBUF(void)
LCD1602_RS0; //RS信号拉低
LCD1602_RW1; //RW信号拉高
LCD1602_EN1;//EN信号拉高
DATA_OUT = 0xFF; //数据端口 11111111全高电平
while((DATA_OUT & 0x80) == 0x80); //判断数据端口PB7 是否一直高
LCD1602_RW1;//RW信号拉高
LCD1602_EN0; //EN信号拉低
//LCD1602写指令子函数
void Write_LCD1602_Instruction_Com(unsigned char Com)
LCD_FBUF(); //读忙状态
LCD1602_RS0; //RS信号拉低写指令
LCD1602_RW0; //RW信号拉低
DATA_OUT = Com; //数据端口指令输入
Delay_us(340); //延时1ms
LCD1602_EN1; //EN信号一个高脉冲
LCD1602_EN0;
//LCD1602写数据子函数
void Write_LCD1602_Instruction_Data(unsigned char Date)
LCD_FBUF(); //读忙状态
LCD1602_RS1; //RS信号拉高写数据指令
LCD1602_RW0;
DATA_OUT = Date; //数据端口数据输入
LCD1602_EN0;
//LCD1602写指令和写数据子函数
void Write_LCD1602_Instruction_Com_Data(unsigned char CountLiey, unsigned char Date)
if(CountLiey == 0) //CountLiey == 0 写指令
Write_LCD1602_Instruction_Com(Date); // 写指令
else //CountLiey !=0 写数据
Write_LCD1602_Instruction_Data(Date); //不等于0写数据
//LCD1602写指令初始化子函数
void Init_LCD1602(void)
Write_LCD1602_Instruction_Com(0x38); //设置16×2显示,5×7点阵,8位数据接口
Delay_us(6); //延时 200us
Write_LCD1602_Instruction_Com(0x0C); //设置打开显示
Write_LCD1602_Instruction_Com(0x06); //读或写一个字符后地址指针加1
Delay_us(6);
Write_LCD1602_Instruction_Com(0x01); //显示清屏
Delay_us(6);
#endif
//========================================END==================================================//
#include "stm32f10x_lib.h"
//#include "DS18B20.H"
typedef volatile unsigned charuint8;
typedef volatile unsigned int uint16;
typedef volatile unsigned longuint32;
//配置GPIO端口
void GPIO_InitStructReadtempCmd(void)
GPIO_InitTypeDef GPIO_InitStruct;
/*GPIO_InitStruct.GPIO_Pin = GPIO_Pin_13;//DS18B20数据脚
GPIO_InitStruct.GPIO_Mode = GPIO_Mode_Out_OD;//开漏输出
GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;//输出速率50MHZ
GPIO_Init(GPIOC, &GPIO_InitStruct); *///GPIOC端口初始化
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_2 |GPIO_Pin_4 | GPIO_Pin_6;// LCD1602 RS-RW-EN脚
GPIO_InitStruct.GPIO_Mode = GPIO_Mode_Out_OD; //开漏输出
GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz; //输出速率50MHZ
GPIO_Init(GPIOE, &GPIO_InitStruct); //GPIOE端口初始
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_0 |GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 |//数据脚 PB0-PB7
GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
GPIO_Init(GPIOD, &GPIO_InitStruct); //GPIOD端口初始化
//配置GPIO外设时钟
void RCC_APB2PeriphReadtempyCmd(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE); // 开启GPIOD外设时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE, ENABLE); // 开启GPIOE外设时钟
//函数主题
int main(void)
RCC_APB2PeriphReadtempyCmd();//外设时钟初始化 //注意外设初始化一定要在GPIO端口配置初始化前面
GPIO_InitStructReadtempCmd(); //GPIO端口配置初始化
while(1)
Write_LCD1602_Instruction_Com_Data(0, 0x80+4); //0是写指令
Write_LCD1602_Instruction_Com_Data(1, 'A' ); //1是写数据
粽子糖果 发表于09-27 09:01 浏览65535次
