在STM32工程中调用printf函数,需要加入如下代码:
- #ifdef __GNUC__
- /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
- set to 'Yes') calls __io_putchar() */
- #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
- #else
- #define PCHAR_PROTOTYPE int fputc(int ch, FILE *f)
- #endif /* __GNUC__ UT*/
- void Printf_Init(void)
- /*!< At this stage the microcontroller clock setting is already configured,
- this is done through SystemInit() function which is called from startup
- file (startup_stm32f10x_xx.s) before to branch to application main.
- To reconfigure the default setting of SystemInit() function, refer to
- system_stm32f10x.c file
- /* USARTx configured as follow:
- - BaudRate = 115200 baud
- - Word Length = 8 Bits
- - One Stop Bit
- - No parity
- - Hardware flow control disabled (RTS and CTS signals)
- - Receive and transmit enabled
- USART_InitStructure.USART_BaudRate = 115200;
- USART_InitStructure.USART_WordLength = USART_WordLength_8b;
- USART_InitStructure.USART_StopBits = USART_StopBits_1;
- USART_InitStructure.USART_Parity = USART_Parity_No;
- USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
- USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
- STM_EVAL_COMInit(COM1, &USART_InitStructure);
- /* Output a message on Hyperterminal using printf function */
- //printf("\n\rUSART Printf Example: retarget the C library printf function to the USART\n\r");
- // printf("\r\n\n\n WWW.ARMJISHU.COM %s configured....", EVAL_COM1_STR);
- // printf("\n\r ############ WWW.ARMJISHU.COM! ############ ("__DATE__ " - " __TIME__ ")\n\r");
- * @brief Retargets the C library printf function to the USART.
- * @param None
- * @retval None
- PUTCHAR_PROTOTYPE
- /* Place your implementation of fputc here */
- /* e.g. write a character to the USART */
- USART_SendData(EVAL_COM1, (uint8_t) ch);
- /* Loop until the end of transmission */
- while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
- return ch;
