KEIL编译错误信息表
错误代码及错误信息 错误释义
error 1: Out of memory 内存溢出
error 2: Identifier expected 缺标识符
error 3: Unknown identifier 未定义的标识符
error 4: Duplicate identifier 重复定义的标识符
error 5: Syntax error 语法错误
error 6: Error in real constant 实型常量错误
error 7: Error in integer constant 整型常量错误
error 8: String constant exceeds line 字符串常量超过一行
error 10: Unexpected end of file 文件非正常结束
error 11: Line too long 行太长
error 12: Type identifier expected 未定义的类型标识符
error 13: Too many open files 打开文件太多
error 14: Invalid file name 无效的文件名
error 15: File not found 文件未找到
error 16: Disk full 磁盘满
error 17: Invalid compiler directive 无效的编译命令
error 18: Too many files 文件太多
error 19: Undefined type in pointer def 指针定义中未定义类型
error 20: Variable identifier expected 缺变量标识符
error 21: Error in type 类型错误
error 22: Structure too large 结构类型太长
error 23: Set base type out of range 集合基类型越界
error 24: File components may not be files or objectsfile分量不能是文件或对象
error 25: Invalid string length 无效的字符串长度
error 26: Type mismatch 类型不匹配
error 27:error 27:Invalid subrange base type 无效的子界基类型
error 28:Lower bound greater than upper bound 下界超过上界
error 29:Ordinal type expected 缺有序类型
error 30:Integer constant expected 缺整型常量
error 31:Constant expected 缺常量
error 32:Integer or real constant expected 缺整型或实型常量
error 33:Pointer Type identifier expected 缺指针类型标识符
error 34:Invalid function result type 无效的函数结果类型
error 35:Label identifier expected 缺标号标识符
error 36:BEGIN expected 缺BEGIN
error 37:END expected 缺END
error 38:Integer expression expected 缺整型表达式
error 39:Ordinal expression expected 缺有序类型表达式
error 40:Boolean expression expected 缺布尔表达式
error 41:Operand types do not match 操作数类型不匹配
error 42:Error in expression 表达式错误
error 43:Illegal assignment 非法赋值
error 44:Field identifier expected 缺域标识符
error 45:Object file too large 目标文件太大
error 46:Undefined external 未定义的外部过程与函数
error 47:Invalid object file record 无效的OBJ文件格式
error 48:Code segment too large 代码段太长
error 49:Data segment too large 数据段太长
error 50:DO expected 缺DO
error 51:Invalid PUBLIC definition 无效的PUBLIC定义
error 52:Invalid EXTRN definition 无效的EXTRN定义
error 53: Too many EXTRN definitions 太多的EXTRN定义
error 54:OF expected 缺OF
error 55:INTERFACE expected 缺INTERFACE
error 56:Invalid relocatable reference 无效的可重定位引用
error 57:THEN expected 缺THEN
error 58:TO or DOWNTO expected 缺TO或DOWNTO
error 59:Undefined forward 提前引用未经定义的说明
error 61:Invalid typecast 无效的类型转换
error 62:Division by zero 被零除
error 63:Invalid file type 无效的文件类型
error 64:Cannot read or write variables of this type 不能读写此类型变量
error 65:Pointer variable expected 缺指针类型变量
error 66:String variable expected 缺字符串变量
error 67:String expression expected 缺字符串表达式
error 68:Circular unit reference 单元UNIT部件循环引用
error 69:Unit name mismatch 单元名不匹配
error 70:Unit version mismatch 单元版本不匹配
error 71:Internal stack overflow 内部堆栈溢出
error 72:Unit file format error 单元文件格式错误
error 73:IMPLEMENTATION expected 缺IMPLEMENTATION
error 74:Constant and case types do not match 常量和CASE类型不匹配
error 75:Record or object variable expected 缺记录或对象变量
error 76:Constant out of range 常量越界
error 77:File variable expected 缺文件变量
error 78:Pointer expression expected 缺指针表达式
error 79:Integer or real expression expected 缺整型或实型表达式
error 80:Label not within current block 标号不在当前块内
error 81:Label already defined 标号已定义
error 82:Undefined label in preceding statement part 在前面未定义标号
error 83:Invalid @ argument 无效的@参数
error 84:UNIT expected 缺UNIT
error 85: ";" expected 缺“;”
error 86: ":" expected 缺“:”
error 87: "," expected 缺“,”
error 88: "(" expected 缺“(”
error 89: ")" expected 缺“)”
error 90: "=" expected 缺“=”
error 91: ":=" expected 缺“:=”
error 92: "[" or "(." Expected 缺“[”或“(.”
error 93: "]" or ".)" expected 缺“]”或“.)”
error 94: "." expected 缺“.”
error 95: ".." expected 缺“..”
error 96:Too many variables 变量太多
error 97:Invalid FOR control variable 无效的FOR循环控制变量
error 98:Integer variable expected 缺整型变量
error 99:Files and procedure types are not allowed here 该处不允许文件和过程类型
error 100:String length mismatch 字符串长度不匹配
error 101:Invalid ordering of fields 无效域顺序
error 102:String constant expected 缺字符串常量
error 103:Integer or real variable expected 缺整型或实型变量
error 104:Ordinal variable expected 缺有序类型变量
error 105:INLINE error INLINE错误
error 106:Character expression expected 缺字符表达式
error 107:Too many relocation items 重定位项太多
error 108:Overflow in arithmetic operation 算术运算溢出
error 112:CASE constant out of range CASE常量越界
error 113:Error in statement 表达式错误
error 114:Cannot call an interrupt procedure 不能调用中断过程
error 116:Must be in 8087 mode to compile this 必须在8087模式编译
error 117:Target address not found 找不到目标地址
error 118:Include files are not allowed here 该处不允许INCLUDE文件
error 119:No inherited methods are accessible here 该处继承方法不可访问
error 121:Invalid qualifier 无效的限定符
error 122:Invalid variable reference 无效的变量引用
error 123:Too many symbols 符号太多
error 124:Statement part too large 语句体太长
error 126:Files must be var parameters 文件必须是变量形参
error 127:Too many conditional symbols 条件符号太多
error 128:Misplaced conditional directive 条件指令错位
error 129:ENDIF directive missing 缺ENDIF指令
error 130:Error in initial conditional defines 初始条件定义错误
error 131:Header does not match previous definition 和前面定义的过程或函数不匹配
error 133:Cannot evaluate this expression 不能计算该表达式
error 134:Expression incorrectly terminated 表达式错误结束
error 135:Invalid format specifier 无效格式说明符
error 136:Invalid indirect reference 无效的间接引用
error 137:Structured variables are not allowed here 该处不允许结构变量
error 138:Cannot evaluate without System unit 没有System单元不能计算
error 139:Cannot access this symbol 不能存取符号
error 140:Invalid floating point operation 无效的符号运算
error 141:Cannot compile overlays to memory 不能编译覆盖模块至内存
error 142:Pointer or procedural variable expected 缺指针或过程变量
error 143:Invalid procedure or function reference 无效的过程或函数调用
error 144:Cannot overlay this unit 不能覆盖该单元
error 146:File access denied 不允许文件访问
error 147:Object type expected 缺对象类型
error 148:Local object types are not allowed 不允许局部对象类型
error 149:VIRTUAL expected 缺VIRTUAL
error 150: Method identifier expected 缺方法标识符
error 151:Virtual constructors are not allowed 不允许虚构造函数
error 152:Constructor identifier expected 缺构造函数标识符
error 153:Destructor identifier expected 缺析构函数标识符
error 154:Fail only allowed within constructors 只能在构造函数内使用Fail标准过程
error 155:Invalid combination of opcode and operands 操作数与操作符无效组合
error 156:Memory reference expected 缺内存引用指针
error 157:Cannot add or subtract relocatable symbols 不能加减可重定位符号
error 158:Invalid register combination 无效寄存器组合
error 159:286/287 instructions are not enabled 未激活286/287指令
error 160:Invalid symbol reference 无效符号指针
error 161:Code generation error 代码生成错误
error 162:ASM expected 缺ASM
error 166:Procedure or function identifier expected 缺过程或函数标识符
error 167:Cannot export this symbol 不能输出该符号
error 168:Duplicate export name 外部文件名重复
error 169:Executable file header too large 可执行文件头太长
error 170:Too many segments 段太多
一、 运行错误信息
运行错误分为四类:1-99为DOS错误;100-149为I/O错误,发生I/O后,如果使用了编译开关{$I+},程序将终止执行,否则编译开关为{$I-},程序继续执行,并由IOResult函数返回错误信息; 150-199为严重错误,200-255为致命错误,致命错误将立即终止程序执行。
错误代码及错误信息 错误释义
error 1:Invalid function number 无效函数号
error 2:File not found 文件未找到
error 3:Path not found 找不到路径
error 4:Too many open files 打开文件太多
error 5:File access denied 文件不允许访问
error 6:Invalid file handle 无效文件句柄
error 12:Invalid file access code 无效文件存取代码
error 15:Invalid drive number 无效驱动器号
error 16:Cannot remove current directory 不能删除当前目录
error 17:Cannot rename across drives 不能跨驱动器改名
error 18:No more files 没有文件了
error 100:Disk read error 读磁盘错
error 101:Disk write error 写磁盘错
error 102:File not assigned 文件变量未赋值
error 103:File not open 文件未打开
error 104:File not open for input 文件未打开为写方式
error 105:File not open for output 文件未打开为读方式
error 106:Invalid numeric format 无效数值格式
error 150:Disk is write-protected 磁盘写保护
error 151:Bad drive request struct length 错误的驱动器请求结构长度
error 152:Drive not ready 驱动器未准备好
error 154:CRC error in data 数据CRC校验错
error 156:Disk seek error 磁盘定位错
error 157:Unknown media type 未知的介质类型
error 158:Sector Not Found 找不到扇区
error 159:Printer out of paper 打印机缺纸
error 160:Device write fault 设备写错误
error 161:Device read fault 设备读错误
error 162:Hardware failure 硬件故障
error 200:Division by zero 被零除
error 201:Range check error 范围检查出错
error 202:Stack overflow error 栈溢出
error 203:Heap overflow error 堆溢出
error 204:Invalid pointer operation 无效的指针操作
error 205:Floating point overflow 浮点运算上溢
error 206:Floating point underflow 浮点运算下溢
error 207:Invalid floating point operation 无效的浮点运算
error 208:Overlay manager not installed 未安装覆盖管理程序
error 209:Overlay file read error 读覆盖文件错误
error 210:Object not initialized 对象未初始化
error 211:Call to abstract method 调用抽象方法
error 212:Stream registration error 流注_册错误
error 213:Collection index out of range 集合下标越界
error 214:Collection overflow error 集合上溢
error 215:Arithmetic overflow error 算术运算上溢
error 216:General Protection fault 一般保护性错误
keil c编译器错误与解决方法
1. Warning 280:’i’:unreferenced local variable
说明局部变量i 在函数中未作任何的存取操作解决方法消除函数中i 变量的宣告
2 Warning 206:’Music3’:missing function-prototype
说明Music3( )函数未作宣告或未作外部宣告所以无法给其他函数调用
解决方法将叙述void Music3(void)写在程序的最前端作宣告如果是其他文件的函数则要写
成extern void Music3(void),即作外部宣告
3 Compling :C:\8051\MANN.C
Error:318:can’t open file ‘beep.h’
说明在编译C:\8051\MANN.C 程序过程中由于main.c 用了指令#i nclude “beep.h”,但
却找不到所致解决方法编写一个beep.h 的包含档并存入到c:\8051 的工作目录中
4 Compling:C:\8051\LED.C
Error 237:’LedOn’:function already has a body
说明LedOn( )函数名称重复定义即有两个以上一样的函数名称
解决方法修正其中的一个函数名称使得函数名称都是独立的
5 ***WARNING 16:UNCALLED SEGMENT,IGNORED FOR OVERLAY PROCESS
SEGMENT: ?PR?_DELAYX1MS?DELAY
说明DelayX1ms( )函数未被其它函数调用也会占用程序记忆体空间解决方法去掉
DelayX1ms( )函数或利用条件编译#if …..#endif,可保留该函数并不编译
6 ***WARNING 6 :XDATA SPACE MEMORY OVERLAP
TO: 0025H
说明外部资料ROM 的0025H 重复定义地址
解决方法外部资料ROM 的定义如下Pdata unsigned char XFR_ADC _at_0x25 其中XFR_ADC
变量的名称为0x25,请检查是否有其它的变量名称也是定义在0x25 处并修正它
7 WARNING 206:’DelayX1ms’: missing function-prototype
C:\8051\INPUT.C
Error 267 :’DelayX1ms ‘:requires ANSI-style prototype C:\8051\INPUT.C
说明程序中有调用DelayX1ms 函数但该函数没定义即未编写程序内容或函数已定义但未作
宣告
解决方法编写DelayX1ms 的内容编写完后也要作宣告或作外部宣告可在delay.h 的包含档
宣告成外部以便其它函数调用
8 ***WARNING 1:UNRESOLVED EXTERNAL SYMBOL
SYMBOL:MUSIC3
MODULE:C:\8051\MUSIC.OBJ(MUSIC)
***WARNING 2:REFERENCE MADE TO UNRESOLVED EXTERNAL
SYMBOL:MUSIC3
ADDRESS:0018H
说明程序中有调用MUSIC 函数但未将该函数的含扩档C 加入到工程档Prj 作编译和连接
解决方法设MUSIC3 函数在MUSIC C 里将MUSIC C 添加到工程文件中去
9 ***ERROR 107:ADDESS SPACE OVERFLOW
SPACE: DATA
SEGMENT: _DATA_GOUP_
LENGTH: 0018H
***ERROR 118: REFERENCE MADE TO ERRONEOUS EXTERNAL
SYMBOL: VOLUME
MODULE: C:\8051\OSDM.OBJ (OSDM)
ADDRESS: 4036H
说明data 存储空间的地址范围为0~0x7f,当公用变量数目和函数里的局部变量如果存
储模式设为SMALL 则局部变量先使用工作寄存器R2~R7 作暂存当存储器不够用时则会
以data 型别的空间作暂存的个数超过0x7f 时就会出现地址不够的现象
解决方法将以data 型别定义的公共变量修改为idata 型别的定义
10.***WARNING L15: MULTIPLE CALL TO SEGMENT
SEGMENT: ?PR?_WRITE_GMVLX1_REG?D_GMVLX1
CALLER1: ?PR?VSYNC_INTERRUPT?MAIN
CALLER2: ?C_C51STARTUP
SEGMENT: ?PR?_SPI_SEND_WORD?D_SPI
SEGMENT: ?PR?SPI_RECEIVE_WORD?D_SPI
该警告表示连接器发现有一个函数可能会被主函数和一个中断服务程序(或者调用中断服务程序的函数)同时调用, 或者同时被多个中断服务程序调用。
出现这种问题的原因之一是这个函数是不可重入性函数,当该函数运行时它可能会被一个中断打断,从而使得结果发生变化并可能会引起一些变量形式的冲突(即引起函数内一些数据的丢失,可重入性函数在任何时候都可以被ISR 打断,一段时间后又可以运行,但是相应数据不会丢失)。
原因之二是用于局部变量和变量(暂且这样翻译,arguments,[自变量,变元一数值,用于确定程序或子程序的值])的内存区被其他函数的内存区所覆盖,如果该函数被中断,则它的内存区就会被使用,这将导致其他函数的内存冲突。
例如,第一个警告中函数WRITE_GMVLX1_REG 在D_GMVLX1.C 或者D_GMVLX1.A51 被定义, 它被一个中断服务程序或者一个调用了中断服务程序的函数调用了,调用它的函数是VSYNC_INTERRUPT,在MAIN.C 中。
解决方法:
如果你确定两个函数决不会在同一时间执行(该函数被主程序调用并且中断被禁止),并且该函数不占用内存(假设只使用寄存器), 则你可以完全忽略这种警告。
如果该函数占用了内存,则应该使用连接器(linker)OVERLAY 指令将函数从覆盖分析(overlay analysis)中除去,例如:
OVERLAY (?PR?_WRITE_GMVLX1_REG?D_GMVLX1 ! *)
上面的指令防止了该函数使用的内存区被其他函数覆盖。如果该函数中调用了其他函数, 而这些被调用在程序中其他地方也被调用, 你可能会需要也将这些函数排除在覆盖分析(overlay analysis)之外。这种OVERLAY 指令能 使编译器除去上述警告信息。
如果函数可以在其执行时被调用,则情况会变得更复杂一些。这时可以采用以下几种方法:
1.主程序调用该函数时禁止中断,可以在该函数被调用时用#pragma disable 语句来实现禁止中断的目的。必须使用OVERLAY 指令将该函数从覆盖分析中除去。
2.复制两份该函数的代码,一份到主程序中,另一份复制到中断服务程序中。
3.将该函数设为重入型。例如:
void myfunc(void) reentrant {
这种设置将会产生一个可重入堆栈,该堆栈被被用于存储函数值和局部变量,用这种方法时重入堆栈必须在STARTUP.A51 文件中配置。
这种方法消耗更多的RAM 并会降低重入函数的执行速度。
11. *** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS
SEGMENT: ?PR?_COMPARE?TESTLCD
说明:程序中有些函数(或片段)以前(调试过程中)从未被调用过,或者根本没有调用它的语句。
这条警告信息前应该还有一条信息指示出是哪个函数导致了这一问题。只要做点简单的调整就可以。不理它也没什么大不了的。
解决方法:去掉COMPARE()函数或利用条件编译#if …..#endif,可保留该函数并不编译。
C 编译器错误信息中文翻译
Ambiguous operators need parentheses 不明确的运算需要用括号括起
Ambiguous symbol ``xxx`` 不明确的符号
Argument list syntax error 参数表语法错误
Array bounds missing 丢失数组界限符
Array size toolarge 数组尺寸太大
Bad character in paramenters 参数中有不适当的字符
Bad file name format in include directive 包含命令中文件名格式不正确
Bad ifdef directive synatax 编译预处理ifdef 有语法错
Bad undef directive syntax 编译预处理undef 有语法错
Bit field too large 位字段太长
Call of non-function 调用未定义的函数
Call to function with no prototype 调用函数时没有函数的说明
Cannot modify a const object 不允许修改常量对象
Case outside of switch 漏掉了case 语句
Case syntax error Case 语法错误
Code has no effect 代码不可述不可能执行到
Compound statement missing{ 分程序漏掉"{"
Conflicting type modifiers 不明确的类型说明符
Constant expression required 要求常量表达式
Constant out of range in comparison 在比较中常量超出范围
Conversion may lose significant digits 转换时会丢失意义的数字
Conversion of near pointer not allowed 不允许转换近指针
Could not find file ``xxx`` 找不到XXX 文件
Declaration missing ; 说明缺少";"
Declaration syntax error 说明中出现语法错误
Default outside of switch Default 出现在switch 语句之外
Define directive needs an identifier 定义编译预处理需要标识符
Division by zero 用零作除数
Do statement must have while Do-while 语句中缺少while 部分
Enum syntax error 枚举类型语法错误
Enumeration constant syntax error 枚举常数语法错误
Error directive :xxx 错误的编译预处理命令
Error writing output file 写输出文件错误
Expression syntax error 表达式语法错误
Extra parameter in call 调用时出现多余错误
File name too long 文件名太长
Function call missing ) 函数调用缺少右括号
Fuction definition out of place 函数定义位置错误
Fuction should return a value 函数必需返回一个值
Goto statement missing label Goto 语句没有标号
Hexadecimal or octal constant too large16 进制或8 进制常数太大
Illegal character ``x`` 非法字符x
Illegal initialization 非法的初始化
Illegal octal digit 非法的8 进制数字
Illegal pointer subtraction 非法的指针相减
Illegal structure operation 非法的结构体操作
Illegal use of floating point 非法的浮点运算
Illegal use of pointer 指针使用非法
Improper use of a typedefsymbol 类型定义符号使用不恰当
In-line assembly not allowed 不允许使用行间汇编
Incompatible storage class 存储类别不相容
Incompatible type conversion 不相容的类型转换
Incorrect number format 错误的数据格式
Incorrect use of default Default 使用不当
Invalid indirection 无效的间接运算
Invalid pointer addition 指针相加无效
Irreducible expression tree 无法执行的表达式运算
Lvalue required 需要逻辑值0 或非0 值
Macro argument syntax error 宏参数语法错误
Macro expansion too long 宏的扩展以后太长
Mismatched number of parameters in definition 定义中参数个数不匹配
Misplaced break 此处不应出现break 语句
Misplaced continue 此处不应出现continue 语句
Misplaced decimal point 此处不应出现小数点
Misplaced elif directive 此处不应出现编译预处理elif
Misplaced else 此处不应出现else
Misplaced else directive 此处不应出现编译预处理else
Misplaced endif directive 此处不应出现编译预处理endif
Must be addressable 必须是可以编址的
Must take address of memory location 必须存储定位的地址
No declaration for function ``xxx`` 没有函数xxx 的说明
No stack 缺少堆栈
No type information 没有类型信息
Non-portable pointer assignment 不可移动的指针(地址常数)赋值
Non-portable pointer comparison 不可移动的指针(地址常数)比较
Non-portable pointer conversion 不可移动的指针(地址常数)转换
Not a valid expression format type 不合法的表达式格式
Not an allowed type 不允许使用的类型
Numeric constant too large 数值常太大
Out of memory 内存不够用
Parameter ``xxx`` is never used 参数xxx 没有用到
Pointer required on left side of -> 符号->的左边必须是指针
Possible use of ``xxx`` before definition 在定义之前就使用了xxx(警告)
Possibly incorrect assignment 赋值可能不正确
Redeclaration of ``xxx`` 重复定义了xxx
Redefinition of ``xxx`` is not identical xxx 的两次定义不一致
Register allocation failure 寄存器定址失败
Repeat count needs an lvalue 重复计数需要逻辑值
Size of structure or array not known 结构体或数给大小不确定
Statement missing ; 语句后缺少";"
Structure or union syntax error 结构体或联合体语法错误
Structure size too large 结构体尺寸太大
Sub scripting missing ] 下标缺少右方括号
Superfluous & with function or array 函数或数组中有多余的"&"
Suspicious pointer conversion 可疑的指针转换
Symbol limit exceeded 符号超限
Too few parameters in call 函数调用时的实参少于函数的参数
Too many default cases Default 太多(switch 语句中一个)
Too many error or warning messages 错误或警告信息太多
Too many type in declaration 说明中类型太多
Too much auto memory in function 函数用到的局部存储太多
Too much global data defined in file 文件中全局数据太多
Two consecutive dots 两个连续的句点
Type mismatch in parameter xxx 参数xxx 类型不匹配
Type mismatch in redeclaration of ``xxx`` xxx 重定义的类型不匹配
Unable to create output file ``xxx`` 无法建立输出文件xxx
Unable to open include file``xxx`` 无法打开被包含的文件xxx
Unable to open input file ``xxx`` 无法打开输入文件xxx
Undefined label ``xxx`` 没有定义的标号xxx
Undefined structure ``xxx`` 没有定义的结构xxx
Undefined symbol ``xxx`` 没有定义的符号xxx
Unexpected end of file in comment started on line xxx 从xxx 行开始的注解尚未结束文件不能结束
Unexpected end of file in conditional started on line xxx 从xxx 开始的条件语句尚未结束文件不能结束
Unknown assemble instruction 未知的汇编结构
Unknown option 未知的操作
Unknown preprocessor directive: ``xxx`` 不认识的预处理命令xxx
Unreachable code 无路可达的代码
Unterminated string or character constant 字符串缺少引号
User break 用户强行中断了程序
Void functions may not return a value Void 类型的函数不应有返回值
Wrong number of arguments 调用函数的参数数目错
``xxx`` not an argument xxx 不是参数
``xxx`` not part of structure xxx 不是结构体的一部分
xxx statement missing ( xxx 语句缺少左括号
xxx statement missing ) xxx 语句缺少右括号
xxx statement missing ; xxx 缺少分号
xxx`` declared but never used 说明了xxx 但没有使用
xxx`` is assigned a value which is never used 给xxx 赋了值但未用过
Zero length structure 结构体的长度为零
在做数据处理的时候,出现warning: #223-D: function "abs" declared implicitly
添加:float abs(float __x);//防止abs warning, 原因不明确, 可能是math.h与stdlib.h中都有abs()吧,用stdlib.h替换math.h也可解决问题
今天在EINT的范例里添加了一个函数,即eint.c中添加了一个datawrite()的函数,并在主函数main.c中调用,编译便警告
warning: #223-D: function "datawrite()" declared implicitly
很奇怪,在eint.c中也有初始化函数EINTInit()同样在main.c中调用没有问题,问什么偏偏这个不行。
但毕竟是个警告,还不是错误,做了个测试IO,
while(1)
    FIO1SET = 1<<19;
   delaySysTick(10);
   Data_write(0xff00, 0xff);
   FIO1CLR = 1<<19;
   delaySysTick(10);
下载执行后发现,此IO根本没有输出。
看来这个警告还是不能回避的,在网上差了下,有类似问题说是库的原因,具体是什么也没说清楚。于是尝试着一一打开库文件,打开eint.h,恍然大悟,这里赫然写着
extern void EINT0_IRQHandler(void) __irq;
extern DWORD EINTInit( void );
原来在这里将eint.c中的函数与main.c相关联,也就是在eint.c中添加了新函数,还有在这里声明调用才行。
eint.h中,添加extern void Data_write(WORD addr, BYTE data);即可
1. warning: #550-D: variable "d" was set but never used
描述:变量'd'定义但从未使用,或者是,虽然这个变量你使用了,但编译器认为变量d所在的语句没有意义,编译器把它优化了.
解决:仔细衡量所定义的变量d是否有用,若是认定变量d所在语句有意义,那么尝试用volatile关键字修饰变量d,若是真的没有用,那么删除掉以释放可能的内存.
2. warning: #1-D: last line of file ends without a newline
描述:文件最后一行不是新的一行.编译器要求程序文件的最后一行必须是空行,想了半天没想通为什么要这样.
解决:可以不理会.若是觉得出现警告不爽,那么在出现警告的文件的最后一行敲个回车,空出一行.
3. warning: #111-D: statement is unreachable
描述:声明不可能到达.多出现在这种场合:
int main(void)
while(1) //无限循环,这在不使用操作系统的程序中最常见
return 0; //这句声明在正常情况下不可能执行到,编译器发出警告
解决:不理会.
4. warning: C3017W: data may be used before being set
描述:变量'data'在使用前没有明确的赋值.如:
uint8 i,data; //定义变量i和data,二者都没有明确赋值
for ( i = 0; i < 8; i++) //变量'i'在语句中被赋值0
if ( IO1PIN & SO_CC2420 )
data |= 0x01; //变量'data'在使用前没有明确赋值,编译器发出警告
else
data &= ~0x01;
解决:应仔细衡量该变量的初始值是否为0,若是,可以不理会这个警告,因为MDK编译器在程序执行前,会将使用到的数据区初始化为0,但若是该变量的初始值不应该是0,忽略这个警告可能会引起致命错误.这个警告应引起足够重视.应养成变量赋初值的习惯,好在有编译器给把关.
5. warning: #177-D: variable "temp" was declared but never referenced
描述:变量'temp'进行了声明但没有引用.多出现在声明了一个变量,但却没有使用它,它和warning: #550-D: variable "temp" was set but never used不同之处在于temp从没有使用过.
解决:若是定义的变量确实没有用,删除掉;若是有用,则在程序中使用.
与该警告类似的还有 warning: #177-D: function "MACProcessBeacon" was declared but never referenced
6. warning: #940-D: missing return statement at end of non-void function "DealwithInspect2"
描述:返回非空的函数"DealwithInspect2"的最后缺少返回值声明.如:
int DealwithInspect2(uint32 test)
//此处应该是return x;返回一个int型数据,若是没有返回值,编译器产生警告
KEIL 中error解决方法
1. error: #65: expected a ";"
描述:缺少分号.大多是漏忘';'.
解决:双击错误行,在定位到错误点的附近找到没加';'号的语句,加上分号.并不一定在定位到的错误行才却分号,可能是这行的上一行,也可能是下一行.
2. error: #65: expected a ";"和 error: #20: identifier "xxxx" is undefined一块出现,而且后面的error: #20错误可能一大堆
描述:这个错误对于第一次遇上的人来说绝对是个噩梦,当错误出现,满怀希望的双击错误提示,来到错误行时却愕然发现,错误行绝对没有错,于是找找错误行的上一行,下一行,没有错误,再找上上行,下下行...让人无比郁闷的事情出现了:编译提示的所有错误行都不可能有错误出现.其实这最可能是你在.h文件声明外部变量或者函数时,没有在声明语句的最后加分号!如果你有很多模块,如main.c,lcd.c,key.c...有很多头文件,如lcd.h,key.h,若是在lcd.h文件声明函数时没有加分号,那么这种错误可能定为到main.c中,所以要检查所有头文件.
解决:仔细检查.h文件,将分号补上.
3.Error: L6200E: Symbol flagu multiply defined (by uart0.o and main.o).
描述:变量(也是一种符号)flagu多处定义(在uart0.c中和main.c都定义了).通常错在全局变量定义重复.比如:在main.c中定义全局变量flagu:
uint8 flagu=0;
在uart0.c中也用到该变量,于是声明此变量,我通常都是先复制定义的变量再在变量前面加关键字extern修饰:
extern uint8 flagu=0;
然后编译,就会出现上面的连接错误,原因在于,我在uart0.c中是又定义了一个变量,而不是声明变量,因为我给变量赋了初值"flagu=0",这样就重复定义了变量flag.正确的声明方法是去掉赋值部分:
extern uint8 flagu;
解决办法:找到重复定义的变量,看情况修改一处.
4. error: #159: declaration is incompatible with previous "wr_lcd" (declared at line 40)
描述:在wr_lcd函数还没有声明之前就已经使用了.多出现在两种情况:第一种,wr_lcd函数体还没有写,就已经用到了它,这种情况多出现在写一个程序的大体结构中,只是简单写一下框架.第二种情况比较常见,函数a调用函数b,但函数b的函数体在函数a的下面:
void a(void) //函数a的实体
b(); //调用函数b
void b(void) //函数b的实体
这样如果点编译,就会产生error: #159的错误,因为当函数a调用函数b时,发现在这之前都没有函数b的任何声明.
解决方法:在函数a调用函数b之前,对函数b进行声明,如:
void b(void); //对函数b进行声明
b(); //调用函数b
5.asm00.sct(7): error: L6236E: No section matches selector - no section to be FIRST/LAST.
解决方法:
Options for Target ' xxxx ',里面的Linker选项下面:
去掉勾选
Use Memory Layout from Target Dialog
清空 Acatter File里面的内容
6.Error: L6411E: No compatible library exists with a definition of startup symbol __main.
Target not created
Warning: L6665W: Neither Lib
Request
armlib Lib
Request
cpplib defined, not
searching ARM libraries.
解决方法:
启动代码里面有一句,它要引用_main这个变量的,默认的启动代码会等一个main函数,如果没有就删除,或者是有,但写错了。
7.error: L6031U: Could not open scatter description file ASM_2.sct: No such file or directory
解决方法:
target option→Linker选项卡下面,取消“scatter file”
KeilMDK STM32 uCOS-II 编译报错:error: #268: declaration may not appear after executable statement in block
编译包含下面代码的文件
* 函数名:Task_USART1
* 描述 : 任务创建函数
* 输入 :*p_arg
* 输出 : 无
void Task_USART1(void *p_arg)
(void)p_arg;
INT8U err;
INT8U *msg;
while(1)
编译结果:
..\APP\app.c(51): error:  #268: declaration may not appear after executable statement in block
分析问题:
这个错误的原因是对于变量的声明不能放在可执行语句后面,必须在主函数开头声明变量。在程序中声明一个变量时,需要在可执行语句之前声明,否则会出现以上错误。
更正:
* 函数名:Task_USART1
* 描述 : 任务创建函数
* 输入 :*p_arg
* 输出 : 无
INT8U err;
INT8U *msg;
(void)p_arg;
while(1)
在uCOS-II中(void)p_arg;
  'p_arg' 并没有用到,防止编译器提示警告,应该放在变量声明之后。
永不止步步 发表于11-03 10:01 浏览65535次
金币:67417个|学分:521796个
