经过can协议分析仪调试过的stm32的can模块收发程序
不多说了,直接上代码
主函数:main.c
#include "main.h"
int main(void)
 SystemInit();
 can_init();
 while(1)
can模块配置的子函数:can.c
#include "can.h"
void can_init(void)
 GPIO_InitTypeDef GPIO_InitStructure;
 NVIC_InitTypeDef NVIC_InitStructure;
 CAN_InitTypeDef CAN_InitStructure;
 CAN_FilterInitTypeDef CAN_FilterInitStructure;
 //NVIC_Configuration
 NVIC_InitStructure.NVIC_IRQChannel = USB_LP_CAN1_RX0_IRQn;
 NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;     // 主优先级为0
 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;            // 次优先级为0
 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
 NVIC_Init(&NVIC_InitStructure);
 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
 RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1, ENABLE);
 //Configure CAN pin: RX
 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
 GPIO_Init(GPIOA, &GPIO_InitStructure);
 //Configure CAN pin: TX
 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
 CAN_DeInit(CAN1);
 CAN_StructInit(&CAN_InitStructure);
 CAN_InitStructure.CAN_TTCM=DISABLE;           // 时间触发通信禁止
 CAN_InitStructure.CAN_ABOM=DISABLE;           // 离线退出是在中断置位清0后退出
 CAN_InitStructure.CAN_AWUM=DISABLE;           // 自动唤醒模式:清零sleep
 CAN_InitStructure.CAN_NART=DISABLE;           // 自动重新传送豹纹,知道发送成功
 CAN_InitStructure.CAN_RFLM=DISABLE;           // FIFO没有锁定,新报文覆盖旧报文
 CAN_InitStructure.CAN_TXFP=DISABLE;           // 发送报文优先级确定:标志符
 CAN_InitStructure.CAN_Mode=CAN_Mode_Normal;   // 模式: CAN_Mode_Normal / CAN_Mode_LoopBack
 CAN_InitStructure.CAN_SJW=CAN_SJW_1tq;        // 1tq、BS1、BS2的值跟波特率有关
 CAN_InitStructure.CAN_BS1=CAN_BS1_8tq;
 CAN_InitStructure.CAN_BS2=CAN_BS2_7tq;
 CAN_InitStructure.CAN_Prescaler=9;       // 分频系数为1
 CAN_Init(CAN1, &CAN_InitStructure);      // 初始化CAN1
 CAN_FilterInitStructure.CAN_FilterNumber=0;
 CAN_FilterInitStructure.CAN_FilterMode=CAN_FilterMode_IdList;
 CAN_FilterInitStructure.CAN_FilterScale=CAN_FilterScale_32bit;
 CAN_FilterInitStructure.CAN_FilterIdHigh=0x014 << 5;
 CAN_FilterInitStructure.CAN_FilterIdLow=0x0000;
 CAN_FilterInitStructure.CAN_FilterMaskIdHigh=0x0000;
 CAN_FilterInitStructure.CAN_FilterMaskIdLow=0x0000;
 CAN_FilterInitStructure.CAN_FilterFIFOAssignment=CAN_FIFO0;
 CAN_FilterInitStructure.CAN_FilterActivation=ENABLE;
 CAN_FilterInit(&CAN_FilterInitStructure);
 CAN_ITConfig(CAN1,CAN_IT_FMP0, ENABLE); //中断使能
void USB_LP_CAN1_RX0_IRQHandler(void)
 CanRxMsg RxMessage;
 RxMessage.StdId=0x00;
 RxMessage.ExtId=0x00;
 RxMessage.IDE=0;
 RxMessage.DLC=0;
 RxMessage.FMI=0;
 RxMessage.Data[0]=0x00;
 RxMessage.Data[1]=0x00;
 CAN_Receive(CAN1, CAN_FIFO0, &RxMessage);
主函数的头文件:main.h
#ifndef  _MAIN_H
#define  _MAIN_H
#include "stm32f10x.h"
#include "can.h"
#endif
子函数的头文件:can.h
#ifndef _CAN_H
#define _CAN_H
#include "main.h"
void can_init(void);
#endif
不明白的地方欢迎提问
永不止步步 发表于11-26 09:49 浏览65535次
