判断字符串通过循环移位是否可以包含另一个字符串
比如说给定字符串“ABCD"通过循环移位是否可以包含“CDAB”。
有两种方法,一种方法就是通过创建另外一个字符串,这个字符串是两个“ABCD”的连接,然后应用kmp在新创建的字符串中查找"CDAB",这样的时间复杂度是O(n), 空间复杂度也是O(n),还有另外一种方法是可在O(n)时间内完成,下面给出代码:
  1. #include<iostream>
  2. #include<string>
  3. #include<stdio.h>
  4. using namespace std;
  5.
  6. void getNext(char* pattern, int length, int* next) {
  7.     int i = 0;
  8.     int j = -1;
  9.     next[i] = -1;
  10.     while (i < length - 1) {
  11.         if (-1 == j || pattern[j] == pattern[i]) {
  12.             ++i;
  13.             ++j;
  14.             if (pattern[i] == pattern[j]) {
  15.                 next[i] = next[j];
  16.             } else {
  17.                 next[i] = j;
  18.             }
  19.         } else {
  20.             j = next[j];
  21.         }
  22.     }
  23. }
  24.
  25. char* kmpSearch(char* source, char* pattern) {
  26.     int src_len = strlen(source);
  27.     int pat_len = strlen(pattern);
  28.     int i, j;
  29.     int* next = new int[pat_len];
  30.     for (i = 0; i < pat_len; i++)
  31.         next[i] = 0;
  32.     getNext(pattern, pat_len, next);
  33.     j = -1;
  34.     i = 0;
  35.     while (i < src_len && j < pat_len) {
  36.         if (-1 == j || source[i] == pattern[j]) {
  37.             ++i;
  38.             ++j;
  39.         } else {
  40.             j = next[j];
  41.         }
  42.     }
  43.     delete []next;
  44.     if (j >= pat_len)
  45.         return source + i - pat_len;
  46.     return NULL;
  47. }
  48.
  49. bool isContainReverse(char* src, char* dst) {
  50.     int src_len = strlen(src);
  51.     int dst_len = strlen(dst);
  52.     if (dst_len > src_len)
  53.         return false;
  54.     char* temp = new char[src_len * 2 + 1];
  55.     sprintf(temp, "%s%s", src, src);
  56.     bool rst = kmpSearch(temp, dst);
  57.     delete []temp;
  58.     return rst;
  59. }
  60.
  61. bool isReverseContain(char* src, char* dst) {
  62.     int dst_contain_count = 0;
  63.     int src_contain_count = 0;
  64.     int src_len = strlen(src);
  65.     int dst_len = strlen(dst);
  66.     char ch = *dst;
  67.     char* p = dst;
  68.     while (*p) {
  69.         if (ch != *p)
  70.             break;
  71.         dst_contain_count++;
  72.         p++;
  73.     }
  74.     p = strchr(src, ch);
  75.     while (p) {
  76.         char* temp = p;
  77.         src_contain_count = 0;
  78.         while (*p) {
  79.             if (ch != *p)
  80.                 break;
  81.             src_contain_count++;
  82.             p++;
  83.         }
  84.         p = strchr(p, ch);
  85.         if (src_contain_count < dst_contain_count)
  86.             continue;
  87.         int i = temp - src + src_contain_count - dst_contain_count;
  88.         int j = 0;
  89.         while (j < dst_len) {
  90.             if (src[i] != dst[j]) {
  91.                 break;
  92.             }
  93.             i = (i + 1) % src_len;
  94.             j += 1;
  95.         }
  96.         if (j >= dst_len)
  97.             return true;
  98.     }
  99.     return false;
  100. }
  101.
  102. int main(int argc, char* argv[]) {
  103.     char src[] = "passportpasssportsssssport";
  104.     char dst[] = "sssssportpassportpasssport";
  105.     bool rst = isReverseContain(src, dst);
  106.     if (rst)
  107.         cout << "yes" << endl;
  108.     else
  109.         cout << "non" << endl;
  110.     cin.get();
  111.     return 0;
  112. }
永不止步步 发表于12-05 11:28 浏览65535次
