STM32F103ZET6 UART4无法进入中断
调了两天UART4,现象是查询方式收发都正常。
但是无法使用中断方式,仿真检查了UART4的寄存器配置完全正常,NVIC寄存器配置也正常。接收数据后NVIC的IABR也相应置位。
更换3.5.0库的startup_stm32f10x_hd.s也不行实在没有办法。
网上查可以REMAP USART3串口使用。
于是使用USART3、和库自带的startup_stm32f10x_hd.s编译下载,现象和UART4一样无法进入中断。
更换回中断生成的 STM32F10x.s 后成功进入USART3中断。由此判断库自带的startup_stm32f10x_hd.s存在问题。
对比STM32F10x.s   和startup_stm32f10x_hd.s文件发现处理XXX_Handler以外还有很多不同的地方。
于是把不同的地方改成与STM32F10x.s一样后,再配置UART4就可以进入中断了。
修改完成的代码贴出来:
;******************** (C) COPYRIGHT 2011 STMicroelectronics ********************
;* File Name          : startup_stm32f10x_hd.s
;* Author             : MCD Application Team
;* Version            : V3.5.0
;* Date               : 11-March-2011
;* Description        : STM32F10x High Density Devices vector table for MDK-ARM
;*                      toolchain.
;*                      This module performs:
;*                      - Set the initial SP
;*                      - Set the initial PC == Reset_Handler
;*                      - Set the vector table entries with the exceptions ISR address
;*                      - Configure the clock system and also configure the external
;*                        SRAM mounted on STM3210E-EVAL board to be used as data
;*                        memory (optional, to be enabled by user)
;*                      - Branches to __main in the C library (which eventually
;*                        calls main()).
;*                      After Reset the CortexM3 processor is in Thread mode,
;*                      priority is Privileged, and the Stack is set to Main.
;* <<< Use Configuration Wizard in Context Menu >>>
; THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
; WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
; AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
; INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
; CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
; INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
; Amount of memory (in bytes) allocated for Stack
; Tailor this value to your application needs
; Stack Configuration
;   Stack Size (in Bytes) <0x0-0xFFFFFFFF:8>
Stack_Size      EQU     0x00000200
                AREA    STACK, NOINIT, READWRITE, ALIGN=3
Stack_Mem       SPACE   Stack_Size
__initial_sp
; Heap Configuration
;     Heap Size (in Bytes) <0x0-0xFFFFFFFF:8>
Heap_Size       EQU     0x00000000
                AREA    HEAP, NOINIT, READWRITE, ALIGN=3
__heap_base
Heap_Mem        SPACE   Heap_Size
__heap_limit
                PRESERVE8
                THUMB
; Vector Table Mapped to Address 0 at Reset
                AREA    RESET, DATA, READONLY
                EXPORT  __Vectors
              ;  EXPORT  __Vectors_End
              ;  EXPORT  __Vectors_Size
__Vectors       DCD     __initial_sp               ; Top of Stack
                DCD     Reset_Handler              ; Reset Handler
                DCD     NMI_Handler                ; NMI Handler
                DCD     HardFault_Handler          ; Hard Fault Handler
                DCD     MemManage_Handler          ; MPU Fault Handler
                DCD     BusFault_Handler           ; Bus Fault Handler
                DCD     UsageFault_Handler         ; Usage Fault Handler
                DCD     0                          ; Reserved
                DCD     0                          ; Reserved
                DCD     0                          ; Reserved
                DCD     0                          ; Reserved
                DCD     SVC_Handler                ; SVCall Handler
                DCD     DebugMon_Handler           ; Debug Monitor Handler
                DCD     0                          ; Reserved
                DCD     PendSV_Handler             ; PendSV Handler
                DCD     SysTick_Handler            ; SysTick Handler
                ; External Interrupts
                DCD     WWDG_IRQHandler            ; Window Watchdog
                DCD     PVD_IRQHandler             ; PVD through EXTI Line detect
                DCD     TAMPER_IRQHandler          ; Tamper
                DCD     RTC_IRQHandler             ; RTC
                DCD     FLASH_IRQHandler           ; Flash
                DCD     RCC_IRQHandler             ; RCC
                DCD     EXTI0_IRQHandler           ; EXTI Line 0
                DCD     EXTI1_IRQHandler           ; EXTI Line 1
                DCD     EXTI2_IRQHandler           ; EXTI Line 2
                DCD     EXTI3_IRQHandler           ; EXTI Line 3
                DCD     EXTI4_IRQHandler           ; EXTI Line 4
                DCD     DMA1_Channel1_IRQHandler   ; DMA1 Channel 1
                DCD     DMA1_Channel2_IRQHandler   ; DMA1 Channel 2
                DCD     DMA1_Channel3_IRQHandler   ; DMA1 Channel 3
                DCD     DMA1_Channel4_IRQHandler   ; DMA1 Channel 4
                DCD     DMA1_Channel5_IRQHandler   ; DMA1 Channel 5
                DCD     DMA1_Channel6_IRQHandler   ; DMA1 Channel 6
                DCD     DMA1_Channel7_IRQHandler   ; DMA1 Channel 7
                DCD     ADC1_2_IRQHandler          ; ADC1 & ADC2
                DCD     USB_HP_CAN1_TX_IRQHandler  ; USB High Priority or CAN1 TX
                DCD     USB_LP_CAN1_RX0_IRQHandler ; USB Low  Priority or CAN1 RX0
                DCD     CAN1_RX1_IRQHandler        ; CAN1 RX1
                DCD     CAN1_SCE_IRQHandler        ; CAN1 SCE
                DCD     EXTI9_5_IRQHandler         ; EXTI Line 9..5
                DCD     TIM1_BRK_IRQHandler        ; TIM1 Break
                DCD     TIM1_UP_IRQHandler         ; TIM1 Update
                DCD     TIM1_TRG_COM_IRQHandler    ; TIM1 Trigger and Commutation
                DCD     TIM1_CC_IRQHandler         ; TIM1 Capture Compare
                DCD     TIM2_IRQHandler            ; TIM2
                DCD     TIM3_IRQHandler            ; TIM3
                DCD     TIM4_IRQHandler            ; TIM4
                DCD     I2C1_EV_IRQHandler         ; I2C1 Event
                DCD     I2C1_ER_IRQHandler         ; I2C1 Error
                DCD     I2C2_EV_IRQHandler         ; I2C2 Event
                DCD     I2C2_ER_IRQHandler         ; I2C2 Error
                DCD     SPI1_IRQHandler            ; SPI1
                DCD     SPI2_IRQHandler            ; SPI2
                DCD     USART1_IRQHandler          ; USART1
                DCD     USART2_IRQHandler          ; USART2
                DCD     USART3_IRQHandler          ; USART3
                DCD     EXTI15_10_IRQHandler       ; EXTI Line 15..10
                DCD     RTCAlarm_IRQHandler        ; RTC Alarm through EXTI Line
                DCD     USBWakeUp_IRQHandler       ; USB Wakeup from suspend
                DCD     TIM8_BRK_IRQHandler        ; TIM8 Break
                DCD     TIM8_UP_IRQHandler         ; TIM8 Update
                DCD     TIM8_TRG_COM_IRQHandler    ; TIM8 Trigger and Commutation
                DCD     TIM8_CC_IRQHandler         ; TIM8 Capture Compare
                DCD     ADC3_IRQHandler            ; ADC3
                DCD     FSMC_IRQHandler            ; FSMC
                DCD     SDIO_IRQHandler            ; SDIO
                DCD     TIM5_IRQHandler            ; TIM5
                DCD     SPI3_IRQHandler            ; SPI3
                DCD     UART4_IRQHandler           ; UART4
                DCD     UART5_IRQHandler           ; UART5
                DCD     TIM6_IRQHandler            ; TIM6
                DCD     TIM7_IRQHandler            ; TIM7
                DCD     DMA2_Channel1_IRQHandler   ; DMA2 Channel1
                DCD     DMA2_Channel2_IRQHandler   ; DMA2 Channel2
                DCD     DMA2_Channel3_IRQHandler   ; DMA2 Channel3
                DCD     DMA2_Channel4_5_IRQHandler ; DMA2 Channel4 & Channel5
                AREA    |.text|, CODE, READONLY
;__Vectors_End
;__Vectors_Size  EQU  __Vectors_End - __Vectors
;                AREA    |.text|, CODE, READONLY
; Reset Handler
Reset_Handler   PROC
                EXPORT  Reset_Handler             [WEAK]
                IMPORT  __main
                LDR     R0, =__main
                BX      R0
                ENDP
; Dummy Exception Handlers (infinite loops which can be modified)
NMI_Handler     PROC
                EXPORT  NMI_Handler               [WEAK]
                B       .
                ENDP
HardFault_Handler\
                PROC
                EXPORT  HardFault_Handler         [WEAK]
                B       .
                ENDP
MemManage_Handler\
                PROC
                EXPORT  MemManage_Handler         [WEAK]
                B       .
                ENDP
BusFault_Handler\
                PROC
                EXPORT  BusFault_Handler          [WEAK]
                B       .
                ENDP
UsageFault_Handler\
                PROC
                EXPORT  UsageFault_Handler        [WEAK]
                B       .
                ENDP
SVC_Handler     PROC
                EXPORT  SVC_Handler               [WEAK]
                B       .
                ENDP
DebugMon_Handler\
                PROC
                EXPORT  DebugMon_Handler          [WEAK]
                B       .
                ENDP
PendSV_Handler  PROC
                EXPORT  PendSV_Handler            [WEAK]
                B       .
                ENDP
SysTick_Handler PROC
                EXPORT  SysTick_Handler           [WEAK]
                B       .
                ENDP
Default_Handler PROC
                EXPORT  WWDG_IRQHandler            [WEAK]
                EXPORT  PVD_IRQHandler             [WEAK]
                EXPORT  TAMPER_IRQHandler          [WEAK]
                EXPORT  RTC_IRQHandler             [WEAK]
                EXPORT  FLASH_IRQHandler           [WEAK]
                EXPORT  RCC_IRQHandler             [WEAK]
                EXPORT  EXTI0_IRQHandler           [WEAK]
                EXPORT  EXTI1_IRQHandler           [WEAK]
                EXPORT  EXTI2_IRQHandler           [WEAK]
                EXPORT  EXTI3_IRQHandler           [WEAK]
                EXPORT  EXTI4_IRQHandler           [WEAK]
                EXPORT  DMA1_Channel1_IRQHandler   [WEAK]
                EXPORT  DMA1_Channel2_IRQHandler   [WEAK]
                EXPORT  DMA1_Channel3_IRQHandler   [WEAK]
                EXPORT  DMA1_Channel4_IRQHandler   [WEAK]
                EXPORT  DMA1_Channel5_IRQHandler   [WEAK]
                EXPORT  DMA1_Channel6_IRQHandler   [WEAK]
                EXPORT  DMA1_Channel7_IRQHandler   [WEAK]
                EXPORT  ADC1_2_IRQHandler          [WEAK]
                EXPORT  USB_HP_CAN1_TX_IRQHandler  [WEAK]
                EXPORT  USB_LP_CAN1_RX0_IRQHandler [WEAK]
                EXPORT  CAN1_RX1_IRQHandler        [WEAK]
                EXPORT  CAN1_SCE_IRQHandler        [WEAK]
                EXPORT  EXTI9_5_IRQHandler         [WEAK]
                EXPORT  TIM1_BRK_IRQHandler        [WEAK]
                EXPORT  TIM1_UP_IRQHandler         [WEAK]
                EXPORT  TIM1_TRG_COM_IRQHandler    [WEAK]
                EXPORT  TIM1_CC_IRQHandler         [WEAK]
                EXPORT  TIM2_IRQHandler            [WEAK]
                EXPORT  TIM3_IRQHandler            [WEAK]
                EXPORT  TIM4_IRQHandler            [WEAK]
                EXPORT  I2C1_EV_IRQHandler         [WEAK]
                EXPORT  I2C1_ER_IRQHandler         [WEAK]
                EXPORT  I2C2_EV_IRQHandler         [WEAK]
                EXPORT  I2C2_ER_IRQHandler         [WEAK]
                EXPORT  SPI1_IRQHandler            [WEAK]
                EXPORT  SPI2_IRQHandler            [WEAK]
                EXPORT  USART1_IRQHandler          [WEAK]
                EXPORT  USART2_IRQHandler          [WEAK]
                EXPORT  USART3_IRQHandler          [WEAK]
                EXPORT  EXTI15_10_IRQHandler       [WEAK]
                EXPORT  RTCAlarm_IRQHandler        [WEAK]
                EXPORT  USBWakeUp_IRQHandler       [WEAK]
                EXPORT  TIM8_BRK_IRQHandler        [WEAK]
                EXPORT  TIM8_UP_IRQHandler         [WEAK]
                EXPORT  TIM8_TRG_COM_IRQHandler    [WEAK]
                EXPORT  TIM8_CC_IRQHandler         [WEAK]
                EXPORT  ADC3_IRQHandler            [WEAK]
                EXPORT  FSMC_IRQHandler            [WEAK]
                EXPORT  SDIO_IRQHandler            [WEAK]
                EXPORT  TIM5_IRQHandler            [WEAK]
                EXPORT  SPI3_IRQHandler            [WEAK]
                EXPORT  UART4_IRQHandler           [WEAK]
                EXPORT  UART5_IRQHandler           [WEAK]
                EXPORT  TIM6_IRQHandler            [WEAK]
                EXPORT  TIM7_IRQHandler            [WEAK]
                EXPORT  DMA2_Channel1_IRQHandler   [WEAK]
                EXPORT  DMA2_Channel2_IRQHandler   [WEAK]
                EXPORT  DMA2_Channel3_IRQHandler   [WEAK]
                EXPORT  DMA2_Channel4_5_IRQHandler [WEAK]
WWDG_IRQHandler
PVD_IRQHandler
TAMPER_IRQHandler
RTC_IRQHandler
FLASH_IRQHandler
RCC_IRQHandler
EXTI0_IRQHandler
EXTI1_IRQHandler
EXTI2_IRQHandler
EXTI3_IRQHandler
EXTI4_IRQHandler
ADC1_2_IRQHandler
CAN1_RX1_IRQHandler
CAN1_SCE_IRQHandler
EXTI9_5_IRQHandler
TIM1_BRK_IRQHandler
TIM1_UP_IRQHandler
TIM1_CC_IRQHandler
TIM2_IRQHandler
TIM3_IRQHandler
TIM4_IRQHandler
I2C1_EV_IRQHandler
I2C1_ER_IRQHandler
I2C2_EV_IRQHandler
I2C2_ER_IRQHandler
SPI1_IRQHandler
SPI2_IRQHandler
USART1_IRQHandler
USART2_IRQHandler
USART3_IRQHandler
RTCAlarm_IRQHandler
TIM8_BRK_IRQHandler
TIM8_UP_IRQHandler
TIM8_CC_IRQHandler
ADC3_IRQHandler
FSMC_IRQHandler
SDIO_IRQHandler
TIM5_IRQHandler
SPI3_IRQHandler
UART4_IRQHandler
UART5_IRQHandler
TIM6_IRQHandler
TIM7_IRQHandler
      B       .
                ENDP
                ALIGN
; User Initial Stack & Heap
                IF      :DEF:__MICROLIB
                EXPORT  __initial_sp
                EXPORT  __heap_base
                EXPORT  __heap_limit
                ELSE
                IMPORT  __use_two_region_memory
                EXPORT  __user_initial_stackheap
                LDR     R0, =  Heap_Mem
                LDR     R1, =(Stack_Mem + Stack_Size)
                LDR     R2, = (Heap_Mem +  Heap_Size)
                LDR     R3, = Stack_Mem
                BX      LR
                ALIGN
                ENDIF
                END
永不止步步 发表于12-06 09:36 浏览65535次
