【我解C语言面试题系列】011 删除指定字符串相应字符
删除指定字符串的相应字符
假设字符串 "cabcdefcgchci" ,那么要求你写一个函数,把该字符串中所有的字符 ’c’ 删除掉。那么结果应该是 "abdefghi"。
00和01是用for循环来实现的算法
char * DeleteChararcter_00(char *str,int c)
    char *p,*ret;
    for(ret= p = str;*p;p++)
       if(*p == c)
           continue;
       *str++ = *p;
    *str = '/0';
    return ret;
char * DeleteChararcter_01(char *str,int c)
    char *p,*ret;
       if(*p != c)
           *str++ = *p;
    *str = '/0';
    return ret;
02和03是用while循环来实现的算法
char * DeleteChararcter_02(char *str,int c)
    char *p,*ret;
    ret = p = str;
    while(*p)
       if(*p++ == c)
           continue;
       *str++ = *(p-1);
    *str = '/0';
    return ret;
char * DeleteChararcter_03(char *str,int c)
    char *p,*ret;
    ret = p = str;
    while(*p)
       if(*p != c)
           *str++ = *p;
       p++;
    *str = '/0';
    return ret;
永不止步步 发表于02-24 11:00 浏览65535次
