C语言画图之画个太极图
呵呵昨天花了一个圆,今天想画个太极图,我知道没啥技术含量,但是挺有意思的,希望各位看官不要鄙视我不务正业,画完此图,不再做这些事情。
先展示下画出来的图像的情况,因为不支持pgm格式的图像,所以我用的 QQ截图:
今天,二话不说上代码。
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <math.h>
typedefstruct{
                size_t width;
                size_t height;
                unsignedchar*data;
}Image;
staticImage *
image_new(size_t width,
                                size_t height)
                Image *image;
                image=malloc(sizeof *image);
                image->width=width;
                image->height=height;
                image->data=malloc(width *height);
                returnimage;
staticvoid
image_free(Image *image)
                free(image->data);
                free(image);
                staticvoid
image_fill(Image *image,
                        unsignedcharvalue)
                memset(image->data,value,image->width *image->height);
* image_set_pixel:
* Sets a pixel passed in signed (x, y) coordinates, where (0,0) is at
* the center of the image.
staticvoid
image_set_pixel(Image *image,
                                ssize_tx,
                                ssize_ty,
                                unsignedcharvalue)
                size_t tx,ty;
                unsignedchar*p;
                tx=(image->width/2)+x;
                ty=(image->height/2)+y;
                p=image->data+(ty *image->width)+tx;
                *p=value;
staticvoid
image_save(constImage *image,
                        constchar*filename)
                FILE *out;
                out=fopen(filename,"wb");
                if(!out)
                                return;
                fprintf(out,"P5\n");
                fprintf(out,"%zu %zu\n",image->width,image->height);
                fprintf(out,"255\n");
                fwrite(image->data,1,image->width *image->height,out);
                fclose(out);
staticvoiddraw_Taijitu(Image *image,intradius,intvalue)
                intx,y;
                intrlimit,llimit;
                intradius_2=radius*radius;
                for(y=-radius;y<radius;y++)
                    for(x=-radius;x<radius;x++)
                       if(x*x+y*y<=radius_2)
                          image_set_pixel(image,x,y,0xff);
                for(y=-radius;y<0;y++)
                    for(x=0;x<radius;x++)
                        if((x*x)+(y*y)<=radius_2)
                          image_set_pixel(image,x,y,value);
                    for(x=-(int)sqrt((double)(-radius*y-y*y));x<0;x++)
                for(y=0;y<radius;y++)
                                llimit=(int)sqrt((double)(radius*y-y*y));
                                rlimit=(int)sqrt((double)(radius_2-y*y));
                                for(x=llimit;x<rlimit;x++)
                for(y=2*radius/6;y<4*radius/6;y++)
                                rlimit=(int)sqrt((double)(radius*y-y*y-2*radius_2/9));
                                llimit=-rlimit;
                for(y=-4*radius/6;y<-2*radius/6;y++)
                                rlimit=sqrt(-radius*y-y*y-2*radius_2/9);
                                llimit=-rlimit;
                return;
                int
main(intargc,char*argv[])
                Image *image;
                image=image_new(800,800);
                image_fill(image,0xaa);
                draw_Taijitu(image,300,0);
                image_save(image,"taiji_6.pgm");
                image_free(image);
                return0;
永不止步步 发表于03-02 11:55 浏览65535次
