stm32中断向量表初探
cortex-M3的异常向量表中的内容并不是指令,0x00000000处(当然也可能映射到别的范围)是主堆栈指针的数值,0x00000004的内容是复位后需要跳转到的地址,是一个地址而不是一条指令。
0x08000000数据如下(memory 窗口查看--STM32小端):
10 02 00 20  05 19 00 08
AREA    RESET, DATA, READONLY
                EXPORT  __Vectors
__Vectors       DCD     __initial_sp              //0x20000210; Top of Stack
                DCD     Reset_Handler             //0x08001905; Reset Handler---最后跳转到main函数
                DCD     NMI_Handler               //0x08001909; NMI Handler
                DCD     HardFault_Handler         //0x0800190B; Hard Fault Handler
                DCD     MemManage_Handler         //0x0800190D; MPU Fault Handler
                DCD     BusFault_Handler          //0x0800190F; Bus Fault Handler
                DCD     UsageFault_Handler        //0x08001911; Usage Fault Handler
                DCD     0                         //0x00000000 ; Reserved
                DCD     0                         //0x00000000; Reserved
                DCD     SVC_Handler               //0x08001913; SVCall Handler
                DCD     DebugMon_Handler          //0x08001915; Debug Monitor Handler
                DCD     0                         ; Reserved
                DCD     PendSV_Handler            //0x08001917; PendSV Handler
                DCD     SysTick_Handler           //0x08000101; SysTick Handler
                ; External Interrupts
                DCD     WWDG_IRQHandler           //0x0800191B; Window Watchdog
                DCD     PVD_IRQHandler            //0x0800191B; PVD through EXTI Line detect
                DCD     TAMPER_IRQHandler         //0x0800191B; Tamper
                DCD     RTC_IRQHandler            //0x0800191B; RTC
                DCD     FLASH_IRQHandler          //0x0800191B; Flash
                DCD     RCC_IRQHandler            //0x0800191B; RCC
                DCD     EXTI0_IRQHandler          //0x0800191B; EXTI Line 0
                DCD     EXTI1_IRQHandler          //0x0800191B; EXTI Line 1
                DCD     EXTI2_IRQHandler          //0x0800191B; EXTI Line 2
                DCD     EXTI3_IRQHandler          //0x0800191B; EXTI Line 3
                DCD     EXTI4_IRQHandler          //0x0800191B; EXTI Line 4
                DCD     DMAChannel1_IRQHandler    //0x0800191B; DMA Channel 1
                DCD     DMAChannel2_IRQHandler    //0x0800191B; DMA Channel 2
                DCD     DMAChannel3_IRQHandler    //0x0800191B; DMA Channel 3
                DCD     DMAChannel4_IRQHandler    //0x0800191B; DMA Channel 4
                DCD     DMAChannel5_IRQHandler    //0x0800191B; DMA Channel 5
                DCD     DMAChannel6_IRQHandler    //0x0800191B; DMA Channel 6
                DCD     DMAChannel7_IRQHandler    //0x0800191B; DMA Channel 7
                DCD     ADC_IRQHandler            //0x0800191B; ADC
                DCD     USB_HP_CAN_TX_IRQHandler  //0x0800191B; USB High Priority or CAN TX
                DCD     USB_LP_CAN_RX0_IRQHandler //0x0800191B; USB Low  Priority or CAN RX0
                DCD     CAN_RX1_IRQHandler        //0x0800191B; CAN RX1
                DCD     CAN_SCE_IRQHandler        //0x0800191B; CAN SCE
                DCD     EXTI9_5_IRQHandler        //0x0800191B; EXTI Line 9..5
                DCD     TIM1_BRK_IRQHandler       //0x0800191B; TIM1 Break
                DCD     TIM1_UP_IRQHandler        //0x0800191B; TIM1 Update
                DCD     TIM1_TRG_COM_IRQHandler   //0x0800191B; TIM1 Trigger and Commutation
                DCD     TIM1_CC_IRQHandler        //0x0800191B; TIM1 Capture Compare
                DCD     TIM2_IRQHandler           //0x0800191B; TIM2
                DCD     TIM3_IRQHandler           //0x0800191B; TIM3
                DCD     TIM4_IRQHandler           //0x0800191B; TIM4
                DCD     I2C1_EV_IRQHandler        //0x0800191B ; I2C1 Event
                DCD     I2C1_ER_IRQHandler        //0x0800191B; I2C1 Error
                DCD     I2C2_EV_IRQHandler        //0x0800191B ; I2C2 Event
                DCD     I2C2_ER_IRQHandler        //0x0800191B ; I2C2 Error
                DCD     SPI1_IRQHandler           //0x0800191B ; SPI1
                DCD     SPI2_IRQHandler           //0x0800191B ; SPI2
                DCD     USART1_IRQHandler         //0x0800191B ; USART1
                DCD     USART2_IRQHandler         //0x0800191B ; USART2
                DCD     USART3_IRQHandler         //0x0800191B ; USART3
                DCD     EXTI15_10_IRQHandler      //0x0800191B ; EXTI Line 15..10
                DCD     RTCAlarm_IRQHandler       //0x0800191B ; RTC Alarm through EXTI Line
0x080000EA      DCD     USBWakeUp_IRQHandler      //0x0800191B ; USB Wakeup from suspend
0x08003608 0x20000000 0x00000010
0x08003618 0x20000010 0x00000200
永不止步步 发表于04-14 14:43 浏览65535次
