C实现 每隔1s向time.txt文件输出系统时间(C I/O函数)
平台:x86/Debian Linux/gcc
1 题目
编程读写一个文件test.txt,每隔1s向文件中写入一行记录,类似于这样:
1 2009-7-30 15:16:42
2 2009-7-30 15:16:43
该程序应该是无限循环,直到按Ctrl + C终止。下次再启动程序时再test.txt文件末尾追加记录,并且序号能够持续上次的序号,比如:
3 2009-7-30 15:19:02
4 2009-7-30 15:19:03
5 2009-7-30 15:19:04
2 编程实现
(1) C代码
  1. /* Filename:    out_date_and_time.c
  2.  * Brife:   Output date and time to time.txt one by one second
  3.  * Date:    2014.8.7 Thursday
  4.  * Author:  One fish
  5.  */
  6. #include <time.h>
  7. #include <stdio.h>
  8. #include <stdlib.h>
  9. #include <string.h>
  10.
  11.
  12.
  13. //------------Maro------------------
  14. #define EPOCH_YEAR  1900
  15. #define EPOCH_MONTH 1
  16. #define EPOCH_DAY   1
  17. #define OUT_FILE    "time.txt"
  18.
  19.
  20.
  21. //------------Function decalre-------
  22. void get_localtime(unsigned long int file_num);
  23. unsigned long int find_file_end(const char *file);
  24.
  25.
  26.
  27. //----------Golbal varibles----------
  28. FILE *fp = NULL;
  29.
  30.
  31.
  32.
  33. int main(void)
  34. {
  35.     unsigned long int file_num = 0;
  36.
  37.     file_num    = find_file_end(OUT_FILE);
  38.     printf("line number: %d\n", file_num);
  39.
  40.     while( 1 ){
  41.         get_localtime( file_num + 1 );
  42.         sleep(1);
  43.     }
  44.     return 0;
  45. }
  46.
  47.
  48.
  49.
  50. /*@Brife:   Open file and find file end line number
  51.  *@Arg:     file is the opened file
  52.  *@Rel:     Return the file number
  53.  */
  54. unsigned long int find_file_end(const char *file)
  55. {
  56.     char buf[30];
  57.     int file_num = 0;
  58.
  59.     fp  = fopen(file, "a+");
  60.     if(NULL != fp){
  61.
  62.         //File is empty
  63.         if( NULL == fgets(buf, 30, fp) )
  64.             return 0;
  65.
  66.         //Move fp to the start of the last line of the file
  67.         fseek(fp, -strlen(buf), SEEK_END);
  68.         fgets(buf, 30, fp);
  69.
  70.         //Or line number bigger than long long int scope
  71.         if(1 != sscanf(buf, "%d", &file_num) ){
  72.             printf("*.txt format is not correct\n");
  73.             return 0;
  74.         }
  75.
  76.         return file_num;
  77.     }else{
  78.         printf("Open %s failed\n", OUT_FILE);
  79.     }
  80. }
  81.
  82.
  83.
  84. /*@Brife:   Get current date and output to time.txt
  85.  *      Should be called after find_file_end()
  86.  *@Arg:     File_num, the line number should be printed
  87.  */
  88. void get_localtime(unsigned long int file_num)
  89. {
  90.
  91.     time_t *t = NULL;
  92.     static unsigned long int num = 0;
  93.     if(num <= file_num){
  94.         num = file_num;
  95.     }
  96.
  97.     t   = (time_t *)malloc(sizeof(time_t));
  98.
  99.     if(NULL != t){
  100.         struct tm *ptm = NULL;
  101.
  102.         //Get the time as the number of seconds since the Epoch, 1970-01-01 00:00 + 0000(UTC)
  103.         //Translate calendar time to broken-down time
  104.         time(t);
  105.         ptm = localtime(t);
  106.
  107.         if(NULL != fp){
  108.             fprintf(fp, "%d %d-%d-%d\t", num, EPOCH_YEAR + ptm->tm_year, EPOCH_MONTH + ptm->tm_mon, EPOCH_MONTH + ptm->tm_mday);
  109.             fprintf(fp, "%d:%d:%d\n", ptm->tm_hour, ptm->tm_min, ptm->tm_sec);
  110.             fflush(fp);
  111.             ++num;
  112.         }else{
  113.             printf("%s Not found\n", OUT_FILE);
  114.         }
  115.     }
  116.     free(t);
  117. }
(2) 运行结果
编译程序:gcc  -o  out_date_and_time  out_date_and_time.c
第一次运行程序一小会后按Ctrl + C终止程序,隔一小会再运行程序。time.txt文件内容如下:
1 2014-8-9    14:40:41
2 2014-8-9    14:40:42
3 2014-8-9    14:40:43
4 2014-8-9    14:40:44
5 2014-8-9    14:40:48
6 2014-8-9    14:40:49
7 2014-8-9    14:40:50
3 man page + 验证
(1) fgets()
原型:char *fgets(char *s, int size, FILE *stream)
用户定义的缓冲区s的sizeof(s)要大于等于size,如果小于size则在fgets读到size-1字符给s后会继续添加一个’\0’字符。使缓冲区s的使用越界。
fgets读一个新建的文件返回NULL。fgets读一个用”backspace”退隔调所有内容的文件,输出fgets的返回值是一个换行。
(2) fseek()
原型:int fseek(FILE  *stream, long  offset, int  whence)
对以下两个不同文件内容:
Figure1.文件1
Figure2.文件2
文件1只有1行数据(1 2014-8-9 15:15:55)并手动输入回车跳到文件1的第二行。文件2的每行内容是由fprintf输出的,行尾带回车。文件1和文件2每行数据长度相同为len,使fp指向文件1时,fseek(fp, -len, SEEK_END)时fp指向1后面的空格。fp指向文件2时,用fseek(fp, -len,SEEK_END)时fp指向第七行(黄色数字为行号)的数字7。
(3) time()和localtime()
用以上代码中time()和localtime()联用,由后者返回struct tm后,加上起始时间后tm_mday比实际时间多一天。
(4) fflush()
原型:fflush(FILE *stream)
因为fprintf属C标准库I/O库函数,stream指向的文件属常规文件(标准输入输出可能为行缓冲),其缓冲类型为全缓冲类型。故而在缓冲区满或程序正常结束前fprintf输出的内容全在缓冲区,在缓冲区未满时按Ctrl + C 后exit()函数没有得到运行,没有得到flush操作,故而stream指向的文件中无内容输出。所以要在每个fprintf函数后面添加ffush()函数,强制进入内核将内容输出到文件中。
永不止步步 发表于04-18 15:48 浏览65535次
