pic单片机查大表程序
收集
list      p=16c77        ;list directive to define processor
    #include         ;processor specific variable definitions
    __CONFIG  _CP_OFF & _WDT_ON & _BODEN_ON & _PWRTE_ON & _XT_OSC
        cblock    0x20
    w_temp                ;variable used for context saving
    status_temp            ;variable used for context saving
    index:2                ;index for larger table look-up
        endc
        ORG    0x000            ; processor reset vector
        clrf    PCLATH            ; ensure page bits are claared
          goto    main              ; go to beginning of program
        ORG    0x004            ; interrupt vector location
        movwf  w_temp            ; save off current W register contents
        movf    STATUS,w          ; move status register into W register
        movwf    status_temp      ; save off contents of STATUS register
; isr code can go here or be located as a call subroutine elsewhere
        movf    status_temp,w    ; retrieve copy of STATUS register
        movwf    STATUS            ; restore pre-isr STATUS register contents
        swapf  w_temp,f
        swapf  w_temp,w          ; restore pre-isr W register contents
        retfie                    ; return from interrupt
main
;测试程序,取表中第800位置的内容
        movlw    low(.800)        ;get low byte of pointer
        movwf    index            ;set to index buffer
        movlw    high(.800)        ;get high byte of pointer
        movwf    index+1            ;set to index+1 buffer
        pagesel    LTABLE            ;make sure page is set correctly
        call    LTABLE            ;call table look-up
                        ;index will be scrambled after call
        pagesel    $            ;make sure page is current
        goto    $            ;code stop here
;This table can be any size and can be located at any position
;regardless of page issue
        org    1000H
LTABLE
        movlw    low(_table_start)    ;get the low byte of actual start address
        addwf    index,f            ;calculate for low byte offset
        skpnc                ;is CARRY?
        incf    index+1,f        ;yes, consider CARRY bit
        movlw    high(_table_start)    ;get the high byte of actual start address
        addwf    index+1,f        ;calculate for high byte offset
        ;now the data pointer is set in index
        movf    index+1,w        ;let PC jump to that location
        movwf    PCLATH
        movf    index,w
        movwf    PCL            ;PC change now!!!
_table_start
DT    0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0x0c,0x0d,0x0e,0x0f
DT    0x10,0x11,0x12,0x13,0x14,0x15,0x16,0x17,0x18,0x19,0x1a,0x1b,0x1c,0x1d,0x1e,0x1f
 DT    0x20,0x21,0x22,0x23,0x24,0x25,0x26,0x27,0x28,0x29,0x2a,0x2b,0x2c,0x2d,0x2e,0x2f
DT    0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39,0x3a,0x3b,0x3c,0x3d,0x3e,0x3f
 DT    0x40,0x41,0x42,0x43,0x44,0x45,0x46,0x47,0x48,0x49,0x4a,0x4b,0x4c,0x4d,0x4e,0x4f
DT    0x50,0x51,0x52,0x53,0x54,0x55,0x56,0x57,0x58,0x59,0x5a,0x5b,0x5c,0x5d,0x5e,0x5f
DT    0x60,0x61,0x62,0x63,0x64,0x65,0x66,0x67,0x68,0x69,0x6a,0x6b,0x6c,0x6d,0x6e,0x6f
DT    0x70,0x71,0x72,0x73,0x74,0x75,0x76,0x77,0x78,0x79,0x7a,0x7b,0x7c,0x7d,0x7e,0x7f
DT    0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87,0x88,0x89,0x8a,0x8b,0x8c,0x8d,0x8e,0x8f
DT    0x90,0x91,0x92,0x93,0x94,0x95,0x96,0x97,0x98,0x99,0x9a,0x9b,0x9c,0x9d,0x9e,0x9f
DT    0xa0,0xa1,0xa2,0xa3,0xa4,0xa5,0xa6,0xa7,0xa8,0xa9,0xaa,0xab,0xac,0xad,0xae,0xaf
DT    0xb0,0xb1,0xb2,0xb3,0xb4,0xb5,0xb6,0xb7,0xb8,0xb9,0xba,0xbb,0xbc,0xbd,0xbe,0xbf
DT    0xc0,0xc1,0xc2,0xc3,0xc4,0xc5,0xc6,0xc7,0xc8,0xc9,0xca,0xcb,0xcc,0xcd,0xce,0xcf
DT    0xd0,0xd1,0xd2,0xd3,0xd4,0xd5,0xd6,0xd7,0xd8,0xd9,0xda,0xdb,0xdc,0xdd,0xde,0xdf
DT    0xe0,0xe1,0xe2,0xe3,0xe4,0xe5,0xe6,0xe7,0xe8,0xe9,0xea,0xeb,0xec,0xed,0xee,0xef
DT    0xf0,0xf1,0xf2,0xf3,0xf4,0xf5,0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfd,0xfe,0xff
END
期待 发表于09-23 16:48 浏览65535次
期待
期待()
金币:32864个|学分:124332个
