型号 | 材料 | 最高电压 | 最大电流 | 最大功率 | 频率 | 沟道电阻 |
MAT02FH | 2 x SI-NPN | 40 V | 20 mA | 0,5 W | 450 MHz | - |
MPSA06 | SI-NPN | 80 V | 0,5 A | 0,625 W | - | - |
MPSA10 | SI-NPN | 40 V | 0,1 A | 0,21 W | 50 MHz | - |
MPSH10 | SI-NPN | 25 V | 40 mA | 0,35 W | 650 MHz | - |
VN10KM | N-FET | 60 V | 0,31 A | - | - | 5,0 Ohm |
MPSA12 | N-DARL | 20 V | 0,5 A | 0,625 W | - | - |
BSR14 | SI-NPN | 75 V | 0,8 A | - | - | - |
MPSA14 | SI-NPN | 30 V | 0,5 A | 0,625 W | - | - |
ASZ15 | GE-PNP | 100 V | 8 A | 30 W | - | - |
BLX15 | SI-NPN | 110 V | 6,5 A | 195 W | 275 MHz | - |
ASZ18 | GE-PNP | 100 V | 8 A | 30 W | - | - |
MPSA18 | SI-NPN | 45 V | 0,2 A | 625 mW | 100 MHz | - |
BSX20 | SI-NPN | 40 V | 0,5 A | 0,36 W | - | - |
IRFZ20 | N-FET | 50 V | 15 A | 40 W | 120 MHz | - |
BSX26 | SI-NPN | 40 V | 0,5 A | 0,36 W | - | - |
ASY27 | GE-PNP | 25 V | 0,2 A | 0,15 W | - | - |
BSX29 | SI-PNP | 12 V | 0,2 A | 0,36 W | 25 MHz | - |
TIP29E | SI-NPN | 180 V | 2 A | 30 W | 3 MHz | - |
IRFBC30 | N-FET | 600 V | 3,9 A | 100 W | - | 2,2 Ohm |
IRFBE30 | N-FET | 800 V | 4,1 A | 125 W | - | 3 Ohm |
BSR31 | SI-PNP | 70 V | 1 A | - | - | - |
BLW32 | SI-NPN | 50 V | 0,65 A | 10 W | 3,5 GHz | - |
BSX32 | SI-NPN | 65 V | 1 A | 0,8 W | - | - |
TIP33C | SI-NPN | 115 V | 10 A | 80 W | - | - |
TIP34C | SI-PNP | 100 V | 10 A | 80 W | 3 MHz | - |
TIP35C | SI-NPN | 100 V | 25 A | 125 W | 3 MHz | - |
TIP36C | SI-PNP | 100 V | 25 A | 125 W | 3 MHz | - |
BSS38 | SI-NPN | 120 V | 0,1 A | 0,2 W | - | - |
IRFBC40 | N-FET | 600 V | 6,2 A | 125 W | - | 1,2 Ohm |
IRFPC40 | N-FET | 600 V | 6,8 A | 150 W | - | 1,2 Ohm |
IRFPE40 | N-FET | 800 V | 5,4 A | 150 W | - | 2 Ohm |
IRFPF40 | N-FET | 900 V | 4,7 A | 150 W | - | 2,5 Ohm |
TIP41C | SI-NPN | 100 V | 6 A | 65 W | 3 MHz | - |
MPSA42 | SI-NPN | 300 V | 0,5 A | 0,625 W | - | - |
TIP42C | SI-PNP | 140 V | 6 A | 65 W | - | - |
BSW43 | SI-NPN | 60 V | 0,2 A | 0,3 W | - | - |
BSS44 | SI-PNP | 65 V | 5 A | 5 W | - | - |
IRFZ44 | N-FET | 60 V | 46 A | 250 W | - | 0,028 Ohm |
MPSA44 | SI-NPN | 500 V | 0,3 A | 625 mW | 20 MHz | - |
BSX47 | SI-NPN | 120 V | 1 A | 5 W | - | - |
IRFZ48 | N-FET | 60 V | 50 A | 250 W | - | 0,018 Ohm |
BSR50 | N-DARL | 60 V | 2 A | 0,8 W | 350 MHz | - |
IRFPC50 | N-FET | 600 V | 13 A | 250 W | - | 0,60 Ohm |
IRFPE50 | N-FET | 900 V | 7,8 A | 190 W | - | 1,2 Ohm |
IRFPF50 | N-FET | 900 V | 6,7 A | 190 W | - | 1,6 Ohm |
TIP50 | SI-NPN | 400 V | 1 A | 40 W | 2 us | - |
BSS52 | N-DARL | 100 V | 1 A | 0,8 W | - | - |
BSV52 | SI-NPN | 20 V | 0,1 A | 225 mW | 400 MHz | - |
BSX52 | SI-NPN | 25 V | 0,2 A | 0,3 W | - | - |
IRFP054 | N-FET | 60 V | 70 A | 230 W | - | 0,014 Ohm |
BSY56 | SI-NPN | 120 V | 0,5 A | 0,8 W | 100 MHz | - |
MPSA56 | SI-PNP | 80 V | 0,5 A | 0,625 W | - | - |
BSX59 | SI-NPN | 45 V | 1 A | 0,8 W | - | - |
BLW60C | SI-NPN | 18 V | 9 A | 100 W | 650 MHz | - |
BSR60 | P-DARL | 45 V | 1 A | 0,8 W | - | - |
IRFP064 | N-FET | 60 V | 70 A | 300 W | - | 0,009 Ohm |
VN66AFD | N-FET | 60 V | 2 A | 12 W | - | 3 Ohm |
BSS68 | SI-PNP | 40 V | 0,8 A | - | - | - |
BSW68A | SI-NPN | 150 V | 2 A | 5 W | 130 MHz | - |
MPSA70 | SI-PNP | 40 V | 0,1 A | 0,35 W | 125 MHz | - |
ASY77 | GE-PNP | 60 V | 1 A | 0,26 W | 500 kHz | - |
BSV80 | N-FET | 40 V | 10 mA | 0,35 W | - | - |
BSV81 | N-FET | 30 V | 50 mA | 0,2 W | - | 100 Ohm |
BSW85 | SI-NPN | 75 V | 0,5 A | 0,5 W | 250 MHz | - |
BLY87C | SI-NPN | 36 V | 1,53 A | 20 W | 175 MHz | - |
BLY88C | SI-NPN | 18 V | 3 A | 36 W | 850 MHz | - |
BSX88 | SI-NPN | 40 V | 0,5 A | 0,36 W | - | - |
VN88AFD | N-FET | 80 V | 1,3 A | 20 W | - | - |
BLY89C | SI-NPN | 18 V | 6 A | 73 W | 800 MHz | - |
BSS89 | N-FET | 240 V | 0,3 A | 1 W | - | 6 Ohm |
BSS91 | N-FET | 200 V | 0,35 A | 1,5 W | - | 6 Ohm |
BSS92 | P-FET | 200 V | 0,15 A | 1 W | 38 MHz | - |
MPSA92 | SI-PNP | 300 V | 0,5 A | 0,625 W | - | - |
BLY93C | SI-NPN | 65 V | 2 A | 25 W | 175 MHz | - |
BLY94 | SI-NPN | 65 V | 6 A | 50 W | 175 MHz | - |
HPA100R | SI-N+D | 1500 V | 10 A | 150 W | - | - |
AL102 | GE-PNP | 130 V | 6 A | 30 W | - | - |
MPF102 | N-FET | 25 V | 2 mA | - | - | - |
TIP102 | N-DARL | 100 V | 8 A | 80 W | - | - |
BS107 | N-FET | 200 V | 0,13 A | 0,8 W | - | 26 Ohm |
TIP107 | P-DARL | 100 V | 15 A | 80 W | - | - |
BS108 | N-FET | 200 V | 0,23 A | 0,8 W | - | 8 Ohm |
J111 | N-FET | 40 V | 50 mA | 0,4 W | - | 30 Ohm |
AL112 | GE-PNP | 130 V | 6 A | 10 W | - | - |
TIP112 | N-DARL | 100 V | 2 A | 50 W | - | - |
DTA114EK | SI-PNP | 50 V | 0,1 A | 0,2 W | - | - |
DTA114ES | SI-PNP | 50 V | 0,1 A | - | - | - |
DTA114TL | SI-PNP | 50 V | 0,1 A | - | - | - |
DTA114YL | SI-PNP | 50 V | 0,1 A | - | - | - |
DTC114ES | SI-NPN | 50 V | 0,1 A | - | - | - |
DTC114TS | SI-NPN | 50 V | 0,1 A | - | - | - |
DTC114YS | SI-NPN | 50 V | 0,1 A | - | - | - |
TIP117 | P-DARL | 100 V | 2 A | 50 W | - | - |
IRF120 | N-FET | 100 V | 9,2 A | 60 W | 58 MHz | - |
IRFD120 | N-FET | 100 V | 1,3 A | 1,3 W | - | 0,27 Ohm |
IRFF120 | N-FET | 100 V | 6 A | 20 W | - | 0,3 Ohm |
BTS121A | N-FET | 100 V | 22 A | 95 W | - | 0,1 Ohm |
TIP122 | N-DARL | 100 V | 5 A | 65 W | - | - |
BSS123 | N-FET | 100 V | 0,17 A | - | - | - |
DTA124ES | SI-PNP | 50 V | 0,1 A | - | - | - |
DTA124XS | SI-PNP | 50 V | 0,1 A | - | - | - |
DTC124EK | SI-NPN | 50 V | 0,1 A | 0,2 W | - | - |
DTC124ES | SI-NPN | 50 V | 0,1 A | - | - | - |
TIP127 | P-DARL | 100 V | 5 A | 65 W | - | - |
TIP132 | N-DARL | 100 V | 8 A | 70 W | - | - |
TIP137 | P-DARL | 100 V | 8 A | 70 W | - | - |
IRF140 | N-FET | 100 V | 28 A | 150 W | - | 0,77 Ohm |
IRFP140 | N-FET | 100 V | 31 A | 180 W | - | O,77 Ohm |
TIP142 | N-DARL | 100 V | 10 A | 125 W | - | - |
TIP142T | N-DARL | 100 V | 10 A | 80 W | - | - |
DTA143EK | SI-PNP | 50 V | 0,1 A | 0,2 W | - | - |
DTA143ES | SI-PNP | 50 V | 0,1 A | - | - | - |
DTC143EK | SI-NPN | 50 V | 0,1 A | 0,2 W | - | - |
DTC143ES | SI-NPN | 50 V | 0,1 A | - | - | - |
DTC143TS | SI-NPN | 50 V | 0,1 A | - | - | - |
DTC143XS | SI-NPN | 50 V | 0,1 A | 0,3 W | - | - |
DTA144EK | SI-PNP | 50 V | 0,1 A | 0,2 W | - | - |
DTA144ES | SI-PNP | 50 V | 0,1 A | - | - | - |
DTA144TS | SI-PNP | 50 V | 0,1 A | 0,3 W | - | - |
DTC144EK | SI-NPN | 50 V | 0,1 A | 0,2 W | - | - |
DTC144ES | SI-NPN | 50 V | 0,1 A | - | - | - |
DTC144EU | SI-NPN | 50 V | 0,1 A | 0,2 W | - | - |
DTC144TS | SI-NPN | 50 V | 0,1 A | 0,3 W | - | - |
DTC144WS | SI-NPN | 50 V | 0,1 A | 0,2 W | - | - |
TIP147 | P-DARL+D | 100 V | 10 A | 125 W | - | - |
HPA150R | SI-N+D | 1500 V | 15 A | 180 W | - | - |
IRFP150 | N-FET | 100 V | 40 A | 180 W | - | 0,55 Ohm |
TIP152 | N-DARL+D | 400 V | 7 A | 80 W | - | - |
TIP162 | N-DARL | 380 V | 10 A | 3 W | - | - |
BS170 | N-FET | 60 V | 0,3 A | 0,8 W | - | 5 Ohm |
THD200FI | SI-NPN | 1500 V | 10 A | 60 W | - | - |
BS208 | P-FET | 200 V | 0,2 A | 0,8 W | - | - |
MJE210 | SI-PNP | 40 V | 5 A | 15 W | 65 MHz | - |
ZTX213 | SI-PNP | 45 V | 0,2 A | 0,3 W | 350 MHz | - |
IRF230 | N-FET | 200 V | 9 A | 75 W | - | 0,4 Ohm |
MRF237 | SI-NPN | 36 V | 0,6 A | 4 W | 174 MHz | - |
IRF240 | N-FET | 200 V | 18 A | 125 W | - | - |
IRFP240 | N-FET | 200 V | 20 A | 150 W | - | 0,18 Ohm |
GD243 | GE-PNP | 65 V | 3 A | 10 W | - | - |
MJE243 | SI-NPN | 100 V | 4 A | 15 W | 40 MHz | - |
BS250 | P-FET | 45 V | 0,18 A | 0,83 W | - | - |
IRF250 | N-FET | 200 V | 30 A | 150 W | - | - |
IRFP250 | N-FET | 200 V | 33 A | 180 W | - | - |
MJE253 | SI-PNP | 100 V | 4 A | 15 W | 40 MHz | - |
BSN254A | N-FET | 250 V | 0,3 A | 1 W | - | 7 Ohm |
MJE270 | N-DARL | 100 V | 2 A | 15 W | 16 MHz | - |
MJE271 | P-DARL | 100 V | 2 A | 15 W | - | - |
BSN274 | N-FET | 270 V | 0,25 A | 1 W | - | 8 Ohm |
J300 | N-FET | 25 V | 6 mA | 0,35 W | - | - |
BSN304 | N-FET | 300 V | 0,25 A | 1 W | - | 8 Ohm |
J309 | N-FET | 25 V | 30 mA | - | - | - |
J310 | N-FET | 25 V | 60 mA | - | - | - |
SGSF313 | SI-NPN | 450 V | 7 A | 70 W | 0,3 us | - |
SGSF313XI | SI-NPN | 1000 V | 5 A | 25 W | 0,3 us | - |
IRF330 | N-FET | 400 V | 5,5 A | 75 W | - | 1 Ohm |
IRF340 | N-FET | 400 V | 10 A | 125 W | 62 MHz | - |
IRFP340 | N-FET | 400 V | 11 A | 150 W | - | 0,55 Ohm |
MJE340 | SI-NPN | 300 V | 0,5 A | 20 W | - | - |
ZTX342 | SI-NPN | 120 V | 0,1 A | 0,3 W | - | - |
SGSF344 | SI-NPN | 600 V | 7 A | 85 W | - | - |
SGSIF344 | SI-NPN | 600 V | 7 A | 35 W | - | - |
IRF350 | N-FET | 400 V | 13 A | 150 W | - | 0,4 Ohm |
