| 型号 | 材料 | 最高电压 | 最大电流 | 最大功率 | 频率 | 沟道电阻 |
| MAT02FH | 2 x SI-NPN | 40 V | 20 mA | 0,5 W | 450 MHz | - |
| MPSA06 | SI-NPN | 80 V | 0,5 A | 0,625 W | - | - |
| MPSA10 | SI-NPN | 40 V | 0,1 A | 0,21 W | 50 MHz | - |
| MPSH10 | SI-NPN | 25 V | 40 mA | 0,35 W | 650 MHz | - |
| VN10KM | N-FET | 60 V | 0,31 A | - | - | 5,0 Ohm |
| MPSA12 | N-DARL | 20 V | 0,5 A | 0,625 W | - | - |
| BSR14 | SI-NPN | 75 V | 0,8 A | - | - | - |
| MPSA14 | SI-NPN | 30 V | 0,5 A | 0,625 W | - | - |
| ASZ15 | GE-PNP | 100 V | 8 A | 30 W | - | - |
| BLX15 | SI-NPN | 110 V | 6,5 A | 195 W | 275 MHz | - |
| ASZ18 | GE-PNP | 100 V | 8 A | 30 W | - | - |
| MPSA18 | SI-NPN | 45 V | 0,2 A | 625 mW | 100 MHz | - |
| BSX20 | SI-NPN | 40 V | 0,5 A | 0,36 W | - | - |
| IRFZ20 | N-FET | 50 V | 15 A | 40 W | 120 MHz | - |
| BSX26 | SI-NPN | 40 V | 0,5 A | 0,36 W | - | - |
| ASY27 | GE-PNP | 25 V | 0,2 A | 0,15 W | - | - |
| BSX29 | SI-PNP | 12 V | 0,2 A | 0,36 W | 25 MHz | - |
| TIP29E | SI-NPN | 180 V | 2 A | 30 W | 3 MHz | - |
| IRFBC30 | N-FET | 600 V | 3,9 A | 100 W | - | 2,2 Ohm |
| IRFBE30 | N-FET | 800 V | 4,1 A | 125 W | - | 3 Ohm |
| BSR31 | SI-PNP | 70 V | 1 A | - | - | - |
| BLW32 | SI-NPN | 50 V | 0,65 A | 10 W | 3,5 GHz | - |
| BSX32 | SI-NPN | 65 V | 1 A | 0,8 W | - | - |
| TIP33C | SI-NPN | 115 V | 10 A | 80 W | - | - |
| TIP34C | SI-PNP | 100 V | 10 A | 80 W | 3 MHz | - |
| TIP35C | SI-NPN | 100 V | 25 A | 125 W | 3 MHz | - |
| TIP36C | SI-PNP | 100 V | 25 A | 125 W | 3 MHz | - |
| BSS38 | SI-NPN | 120 V | 0,1 A | 0,2 W | - | - |
| IRFBC40 | N-FET | 600 V | 6,2 A | 125 W | - | 1,2 Ohm |
| IRFPC40 | N-FET | 600 V | 6,8 A | 150 W | - | 1,2 Ohm |
| IRFPE40 | N-FET | 800 V | 5,4 A | 150 W | - | 2 Ohm |
| IRFPF40 | N-FET | 900 V | 4,7 A | 150 W | - | 2,5 Ohm |
| TIP41C | SI-NPN | 100 V | 6 A | 65 W | 3 MHz | - |
| MPSA42 | SI-NPN | 300 V | 0,5 A | 0,625 W | - | - |
| TIP42C | SI-PNP | 140 V | 6 A | 65 W | - | - |
| BSW43 | SI-NPN | 60 V | 0,2 A | 0,3 W | - | - |
| BSS44 | SI-PNP | 65 V | 5 A | 5 W | - | - |
| IRFZ44 | N-FET | 60 V | 46 A | 250 W | - | 0,028 Ohm |
| MPSA44 | SI-NPN | 500 V | 0,3 A | 625 mW | 20 MHz | - |
| BSX47 | SI-NPN | 120 V | 1 A | 5 W | - | - |
| IRFZ48 | N-FET | 60 V | 50 A | 250 W | - | 0,018 Ohm |
| BSR50 | N-DARL | 60 V | 2 A | 0,8 W | 350 MHz | - |
| IRFPC50 | N-FET | 600 V | 13 A | 250 W | - | 0,60 Ohm |
| IRFPE50 | N-FET | 900 V | 7,8 A | 190 W | - | 1,2 Ohm |
| IRFPF50 | N-FET | 900 V | 6,7 A | 190 W | - | 1,6 Ohm |
| TIP50 | SI-NPN | 400 V | 1 A | 40 W | 2 us | - |
| BSS52 | N-DARL | 100 V | 1 A | 0,8 W | - | - |
| BSV52 | SI-NPN | 20 V | 0,1 A | 225 mW | 400 MHz | - |
| BSX52 | SI-NPN | 25 V | 0,2 A | 0,3 W | - | - |
| IRFP054 | N-FET | 60 V | 70 A | 230 W | - | 0,014 Ohm |
| BSY56 | SI-NPN | 120 V | 0,5 A | 0,8 W | 100 MHz | - |
| MPSA56 | SI-PNP | 80 V | 0,5 A | 0,625 W | - | - |
| BSX59 | SI-NPN | 45 V | 1 A | 0,8 W | - | - |
| BLW60C | SI-NPN | 18 V | 9 A | 100 W | 650 MHz | - |
| BSR60 | P-DARL | 45 V | 1 A | 0,8 W | - | - |
| IRFP064 | N-FET | 60 V | 70 A | 300 W | - | 0,009 Ohm |
| VN66AFD | N-FET | 60 V | 2 A | 12 W | - | 3 Ohm |
| BSS68 | SI-PNP | 40 V | 0,8 A | - | - | - |
| BSW68A | SI-NPN | 150 V | 2 A | 5 W | 130 MHz | - |
| MPSA70 | SI-PNP | 40 V | 0,1 A | 0,35 W | 125 MHz | - |
| ASY77 | GE-PNP | 60 V | 1 A | 0,26 W | 500 kHz | - |
| BSV80 | N-FET | 40 V | 10 mA | 0,35 W | - | - |
| BSV81 | N-FET | 30 V | 50 mA | 0,2 W | - | 100 Ohm |
| BSW85 | SI-NPN | 75 V | 0,5 A | 0,5 W | 250 MHz | - |
| BLY87C | SI-NPN | 36 V | 1,53 A | 20 W | 175 MHz | - |
| BLY88C | SI-NPN | 18 V | 3 A | 36 W | 850 MHz | - |
| BSX88 | SI-NPN | 40 V | 0,5 A | 0,36 W | - | - |
| VN88AFD | N-FET | 80 V | 1,3 A | 20 W | - | - |
| BLY89C | SI-NPN | 18 V | 6 A | 73 W | 800 MHz | - |
| BSS89 | N-FET | 240 V | 0,3 A | 1 W | - | 6 Ohm |
| BSS91 | N-FET | 200 V | 0,35 A | 1,5 W | - | 6 Ohm |
| BSS92 | P-FET | 200 V | 0,15 A | 1 W | 38 MHz | - |
| MPSA92 | SI-PNP | 300 V | 0,5 A | 0,625 W | - | - |
| BLY93C | SI-NPN | 65 V | 2 A | 25 W | 175 MHz | - |
| BLY94 | SI-NPN | 65 V | 6 A | 50 W | 175 MHz | - |
| HPA100R | SI-N+D | 1500 V | 10 A | 150 W | - | - |
| AL102 | GE-PNP | 130 V | 6 A | 30 W | - | - |
| MPF102 | N-FET | 25 V | 2 mA | - | - | - |
| TIP102 | N-DARL | 100 V | 8 A | 80 W | - | - |
| BS107 | N-FET | 200 V | 0,13 A | 0,8 W | - | 26 Ohm |
| TIP107 | P-DARL | 100 V | 15 A | 80 W | - | - |
| BS108 | N-FET | 200 V | 0,23 A | 0,8 W | - | 8 Ohm |
| J111 | N-FET | 40 V | 50 mA | 0,4 W | - | 30 Ohm |
| AL112 | GE-PNP | 130 V | 6 A | 10 W | - | - |
| TIP112 | N-DARL | 100 V | 2 A | 50 W | - | - |
| DTA114EK | SI-PNP | 50 V | 0,1 A | 0,2 W | - | - |
| DTA114ES | SI-PNP | 50 V | 0,1 A | - | - | - |
| DTA114TL | SI-PNP | 50 V | 0,1 A | - | - | - |
| DTA114YL | SI-PNP | 50 V | 0,1 A | - | - | - |
| DTC114ES | SI-NPN | 50 V | 0,1 A | - | - | - |
| DTC114TS | SI-NPN | 50 V | 0,1 A | - | - | - |
| DTC114YS | SI-NPN | 50 V | 0,1 A | - | - | - |
| TIP117 | P-DARL | 100 V | 2 A | 50 W | - | - |
| IRF120 | N-FET | 100 V | 9,2 A | 60 W | 58 MHz | - |
| IRFD120 | N-FET | 100 V | 1,3 A | 1,3 W | - | 0,27 Ohm |
| IRFF120 | N-FET | 100 V | 6 A | 20 W | - | 0,3 Ohm |
| BTS121A | N-FET | 100 V | 22 A | 95 W | - | 0,1 Ohm |
| TIP122 | N-DARL | 100 V | 5 A | 65 W | - | - |
| BSS123 | N-FET | 100 V | 0,17 A | - | - | - |
| DTA124ES | SI-PNP | 50 V | 0,1 A | - | - | - |
| DTA124XS | SI-PNP | 50 V | 0,1 A | - | - | - |
| DTC124EK | SI-NPN | 50 V | 0,1 A | 0,2 W | - | - |
| DTC124ES | SI-NPN | 50 V | 0,1 A | - | - | - |
| TIP127 | P-DARL | 100 V | 5 A | 65 W | - | - |
| TIP132 | N-DARL | 100 V | 8 A | 70 W | - | - |
| TIP137 | P-DARL | 100 V | 8 A | 70 W | - | - |
| IRF140 | N-FET | 100 V | 28 A | 150 W | - | 0,77 Ohm |
| IRFP140 | N-FET | 100 V | 31 A | 180 W | - | O,77 Ohm |
| TIP142 | N-DARL | 100 V | 10 A | 125 W | - | - |
| TIP142T | N-DARL | 100 V | 10 A | 80 W | - | - |
| DTA143EK | SI-PNP | 50 V | 0,1 A | 0,2 W | - | - |
| DTA143ES | SI-PNP | 50 V | 0,1 A | - | - | - |
| DTC143EK | SI-NPN | 50 V | 0,1 A | 0,2 W | - | - |
| DTC143ES | SI-NPN | 50 V | 0,1 A | - | - | - |
| DTC143TS | SI-NPN | 50 V | 0,1 A | - | - | - |
| DTC143XS | SI-NPN | 50 V | 0,1 A | 0,3 W | - | - |
| DTA144EK | SI-PNP | 50 V | 0,1 A | 0,2 W | - | - |
| DTA144ES | SI-PNP | 50 V | 0,1 A | - | - | - |
| DTA144TS | SI-PNP | 50 V | 0,1 A | 0,3 W | - | - |
| DTC144EK | SI-NPN | 50 V | 0,1 A | 0,2 W | - | - |
| DTC144ES | SI-NPN | 50 V | 0,1 A | - | - | - |
| DTC144EU | SI-NPN | 50 V | 0,1 A | 0,2 W | - | - |
| DTC144TS | SI-NPN | 50 V | 0,1 A | 0,3 W | - | - |
| DTC144WS | SI-NPN | 50 V | 0,1 A | 0,2 W | - | - |
| TIP147 | P-DARL+D | 100 V | 10 A | 125 W | - | - |
| HPA150R | SI-N+D | 1500 V | 15 A | 180 W | - | - |
| IRFP150 | N-FET | 100 V | 40 A | 180 W | - | 0,55 Ohm |
| TIP152 | N-DARL+D | 400 V | 7 A | 80 W | - | - |
| TIP162 | N-DARL | 380 V | 10 A | 3 W | - | - |
| BS170 | N-FET | 60 V | 0,3 A | 0,8 W | - | 5 Ohm |
| THD200FI | SI-NPN | 1500 V | 10 A | 60 W | - | - |
| BS208 | P-FET | 200 V | 0,2 A | 0,8 W | - | - |
| MJE210 | SI-PNP | 40 V | 5 A | 15 W | 65 MHz | - |
| ZTX213 | SI-PNP | 45 V | 0,2 A | 0,3 W | 350 MHz | - |
| IRF230 | N-FET | 200 V | 9 A | 75 W | - | 0,4 Ohm |
| MRF237 | SI-NPN | 36 V | 0,6 A | 4 W | 174 MHz | - |
| IRF240 | N-FET | 200 V | 18 A | 125 W | - | - |
| IRFP240 | N-FET | 200 V | 20 A | 150 W | - | 0,18 Ohm |
| GD243 | GE-PNP | 65 V | 3 A | 10 W | - | - |
| MJE243 | SI-NPN | 100 V | 4 A | 15 W | 40 MHz | - |
| BS250 | P-FET | 45 V | 0,18 A | 0,83 W | - | - |
| IRF250 | N-FET | 200 V | 30 A | 150 W | - | - |
| IRFP250 | N-FET | 200 V | 33 A | 180 W | - | - |
| MJE253 | SI-PNP | 100 V | 4 A | 15 W | 40 MHz | - |
| BSN254A | N-FET | 250 V | 0,3 A | 1 W | - | 7 Ohm |
| MJE270 | N-DARL | 100 V | 2 A | 15 W | 16 MHz | - |
| MJE271 | P-DARL | 100 V | 2 A | 15 W | - | - |
| BSN274 | N-FET | 270 V | 0,25 A | 1 W | - | 8 Ohm |
| J300 | N-FET | 25 V | 6 mA | 0,35 W | - | - |
| BSN304 | N-FET | 300 V | 0,25 A | 1 W | - | 8 Ohm |
| J309 | N-FET | 25 V | 30 mA | - | - | - |
| J310 | N-FET | 25 V | 60 mA | - | - | - |
| SGSF313 | SI-NPN | 450 V | 7 A | 70 W | 0,3 us | - |
| SGSF313XI | SI-NPN | 1000 V | 5 A | 25 W | 0,3 us | - |
| IRF330 | N-FET | 400 V | 5,5 A | 75 W | - | 1 Ohm |
| IRF340 | N-FET | 400 V | 10 A | 125 W | 62 MHz | - |
| IRFP340 | N-FET | 400 V | 11 A | 150 W | - | 0,55 Ohm |
| MJE340 | SI-NPN | 300 V | 0,5 A | 20 W | - | - |
| ZTX342 | SI-NPN | 120 V | 0,1 A | 0,3 W | - | - |
| SGSF344 | SI-NPN | 600 V | 7 A | 85 W | - | - |
| SGSIF344 | SI-NPN | 600 V | 7 A | 35 W | - | - |
| IRF350 | N-FET | 400 V | 13 A | 150 W | - | 0,4 Ohm |
