记使用Android SQLite遇到的小问题
之前一直是遇到activity需要保存数据就直接使用SQLite就好,但是有一天突然发现,我需要在其中一个Activity里访问另一个Activity建立的SQLiteDatabase,从而引出了该文。
查了很多资料,大多数都是说,使用单例模式建立继承SQLiteOpenHelper的类,然后使用静态方法(一般取名getInstance)来获得。自己亲自尝试了,发现总是不对,于是找了一种更简便更懒的方法(直接用文件位置引用数据库):
SettingActivity.java
db = openOrCreateDatabase("callon_set_pump", Context.MODE_PRIVATE, null);
if(tabbleIsExist("table1")){
DatabaseHelper dbHelper = new DatabaseHelper(SettingActivity.this, "callon_set_pump");
SQLiteDatabase db = dbHelper.getReadableDatabase();
Cursor cursor = db.query("table1", new String[]{"id","name"}, "id=?", new String[]{"1"}, null, null, null);
while(cursor.moveToNext()){
String name = cursor.getString(cursor.getColumnIndex("name"));
//add your code here
cursor = db.query("table1", new String[]{"id","name"}, "id=?", new String[]{"2"}, null, null, null);
cursor = db.query("table1", new String[]{"id","name"}, "id=?", new String[]{"3"}, null, null, null);
cursor = db.query("table1", new String[]{"id","name"}, "id=?", new String[]{"4"}, null, null, null);
cursor = db.query("table1", new String[]{"id","name"}, "id=?", new String[]{"5"}, null, null, null);
else {
db.execSQL("CREATE TABLE table1(id int,name varchar(20))");
ContentValues values = new ContentValues();
values.put("id", 1);
values.put("name", "5000");
db.insert("table1", null, values);
values.put("id", 2);
values.put("name", "1000");
values.put("id", 3);
values.put("name", "3");
values.put("id", 4);
values.put("id", 5);
values.put("name", "NONE");
上述类建立了一个数据库callon_set_pump,在另一个类中使用的话,
PageActivity.java
db_set = SQLiteDatabase.openOrCreateDatabase("data/data/com.autopump.callon.nenu/databases/callon_set_pump",null);
Cursor cursor = db_set.query("table1", new String[]{"id","name"}, "id=?", new String[]{"1"}, null, null, null);
System.out.println("name is :"+ name);
关于tabbleIsExist方法,它是用来检测是否存在该数据库的,如果存在重复创建会出现异常的哦~
private boolean tabbleIsExist(String tableName){
boolean result = false;
if(tableName == null){
return false;
SQLiteDatabase db = null;
Cursor cursor = null;
try {
String sql = "select count(*) as c from Sqlite_master where type ='table' and name ='"+tableName.trim()+"' ";
cursor = db.rawQuery(sql, null);
if(cursor.moveToNext()){
int count = cursor.getInt(0);
if(count>0){
result = true;
} catch (Exception e) {
// TODO: handle exception
return result;
总之能抓到耗子的就是好猫吧,虽然方法不像什么单例模式那样洋气,希望对大家有帮助。
永不止步步 发表于04-18 09:42 浏览65535次
