小玩意,3个普通IO识别22个按键试验。附实物和程序
吸取前辈经验,将之前二极管用量多的问题优化一下,目前不用二极管能接6键,2只二极管能接12键,6只二极管能接18键,9只二极管能接21键,第22键要单独占用3只二极管最不化算。
实验用89S51作试验,电路接线就是P1.2,P1.3,P1.4接键盘,P1.0接显示器。
* 3个IO接识别22键测试程序 *
* MCU: AT89C2051 *
* OSC: 12M cysytel *
* 程序设计:Cowboy *
* 程序版本:V1.0 *
#include<reg52.h>
//================== IO口线连接 ==================
sbit Bus = P1^0;
sbit IO_a = P1^4;
sbit IO_b = P1^3;
sbit IO_c = P1^2;
//================== 变量声明 ====================
unsigned char Disp_buf[3];
unsigned char Dig;
unsigned char Key_count;
unsigned char bdata Key_state;
sbit KB0 = Key_state^0;
sbit KB1 = Key_state^1;
sbit KB2 = Key_state^2;
sbit KB3 = Key_state^3;
sbit KB4 = Key_state^4;
sbit KB5 = Key_state^5;
//================== 表格数据 ====================
code unsigned char LED_font[24]=
0x84,0x9f,0xa2,0x8a,0x99,0xc8,0xc0,0x9e,0x80, //012345678
0x88,0x90,0xc1,0xe4,0x83,0xe0,0xf0,0xff,0xfb, //9abcdef -
code unsigned char Key_tab[64]= //键码映射表
{// 0 1 2 3 4 5 6 7 8 9
22, 0, 2, 0, 0, 0, 0, 0, 4, 0, //0
0, 0, 0, 0, 0,18, 0, 0, 0, 0, //1X
0, 0, 0, 0, 0, 0, 3,14, 0, 0, //2X
20,10, 6, 0, 0, 0, 0, 0, 1,19, //3X
0, 5, 0, 0, 0,15, 0,11, 0, 0, //4X
0,17, 0, 0,13, 8, 0,21, 0, 9, //5X
16,12, 7, 0 //6X
//=============== 检测按键 =================
void Key_scan()
unsigned char i;
Key_count --; //扫描次序
Key_count &= 3;
switch (Key_count) //按次序处理
case 2: //第一轮扫描
KB0 = IO_b;
KB1 = IO_c;
IO_a = 1;
IO_b = 0;
break;
case 1: //每二轮扫描
KB2 = IO_c;
KB3 = IO_a;
IO_b = 1;
IO_c = 0;
break;
case 0: //每三轮扫描
KB4 = IO_a;
KB5 = IO_b;
IO_c = 1;
break;
default: //每四轮扫描
if (!IO_a) KB0 = 0;
if (!IO_b) KB2 = 0;
if (!IO_c) KB4 = 0;
IO_a = 0;
//======更新显示缓冲区=======
i = Key_tab[Key_state];
if (i == 0)
Disp_buf[2] = 0x11; //显示三横
Disp_buf[1] = 0x11;
Disp_buf[0] = 0x11;
else
Disp_buf[2] = 0x0c; //字符"C"
Disp_buf[1] = i / 10; //键码十位
Disp_buf[0] = B;于 //键码个位
Key_state = 0;
ONE WIRE 显示总线驱动程序
//=============== 发送一位 =================
void Send_bit(bit Dat)
unsigned char i = 3;
if (!Dat) Bus = 0;
else
Bus = 0;
Bus = 1;
while(--i); //延时8us
Bus = 1;
//=============== 总线驱动 =================
void Bus_drive()
unsigned char i = 0;
unsigned char Sdat;
Send_bit(1); //Bit6消隐
do Bus = 1; while(--i); //延时768us
do Bus = 0; while(--i); //延时768us
Bus = 1;
Sdat = LED_font[Disp_buf[Dig++]]; //获取显示数据
Send_bit(Sdat & 0x01); //发送位0
Send_bit(Sdat & 0x02); //发送位1
Send_bit(Sdat & 0x04); //发送位2
Send_bit(Sdat & 0x08); //发送位3
Send_bit(Sdat & 0x10); //发送位4
Send_bit(Sdat & 0x20); //发送位5
Send_bit(Dig & 0x01); //发送位选1
Send_bit(Dig & 0x02); //发送位选2
while(--i); //延时512us
Send_bit(Sdat & 0x40); //发送位6
for (i = 7;i> 0;i--) Send_bit(1); //位6移至Dout
if (Dig == 3) Dig = 0;
延时 5ms 程序
void Delay_5ms()
while(!TF1);
TF1 = 0;
TH1 = (- 5000) / 256;
TL1 = (- 5000) % 256;
主程序
void main()
TMOD = 0x10; //定时器1,16位模式
TCON = 0xc0; //TR1=1;TF1=1;
while(1) //主循环
Bus_drive(); //显示总线驱动
Key_scan(); //检测按键
Delay_5ms(); //延时5MS
下次焊个四面体的4IO玩玩看
二极管数量
6条楞,每楞两个,12个
中间星型,4个
共16个
作为试验目的,没有接按键,只焊了个键盘框架,用镊子短路相应的节点来当按键。图中接二极管阵列的三根线是3个IO,单独的一根是地线。MCU发送串行数据给HC595驱动数码管作键码显示。
对于这种方式的按键识别方法,很多朋友担心编程会很复杂,其实仔细分析后也很简单.比如上面例子,其本的思路是依次把三个IO拉低,然后记录另外两个IO的状态,最后三个IO都不下拉,再记录一次,就可得出的结果.对于按下不同的按键,就有不同的结果.如果只扫18键,那么最后一次扫描可以省掉,即扫描三次即可.实际应用时5MS的扫描间隔可以用定时中断来实现,这样就只占用很少的MCU时间.
永不止步步 发表于11-01 10:45 浏览65535次
