FPGA xilinx 程序调试出错
WARNING:PhysDesignRules:372 - Gated clock. Clock net rd_en is sourced by a combinatorial pin. This is not good design practice. Use the CE pin to  control the loading of data into the flip-flop.
reg rd_en;
always @(*)
begin
rd_en <= ~csn && ~rdn;
WR_RISING <= ~csn && ~wrn;
end
always @(posedge rd_en)
begin
if(rd_en == 1)
begin
case(addr[2:0])
3'b000:data_reg <= ARM_FPGA_REG0;
3'b001:data_reg <= ARM_FPGA_REG1;
3'b010:data_reg <= ARM_FPGA_REG2;
3'b011:data_reg <= ARM_FPGA_REG3;
3'b100:data_reg <= ARM_FPGA_REG4;
3'b101:data_reg <= ARM_FPGA_REG5;
3'b110:data_reg <= ARM_FPGA_REG6;
3'b111:data_reg <= ARM_FPGA_REG7;
default:;
endcase
end
end
程序用到rd_en的地方,麻烦高手指点下,非常感谢!
由于有以下一行:
综合工具会认为rd_en是时钟。所以有这个WARNING。假设真实时钟是clk,可以改为:
always @(posedge clk)
这样rd_en就会被综合成寄存器的CE(时钟使能)控制信号。
永不止步步 发表于04-05 10:33 浏览65535次
