AVR单片机nRF24L01发送接收驱动程序
#include "iom16v.h"
#include "macros.h"
#include "12864.h"
//spi标志
#define DDR_SPI DDRB
#define DD_MOSI 5
#define DD_MISO 6
#define DD_SCK 7
#define DD_SS 4
#define CE PB3
#define IRQ PB2
//--------------------------------NRF24L01接口定义--------------------------------
//#define NRF24L01_MISO PB6 //输入0
#define Hign_24L01_MISO PORTB|=(1 << PB6)
#define Low_24L01_MISO PORTB &= ~(1 << PB6)
#define Read_24L01_MISO PINB & (1 << PB6)
//#define NRF24L01_MOSI PB5 //输出1
#define Hign_24L01_MOSI PORTB |= (1 << PB5)
#define Low_24L01_MOSI PORTB &= ~(1 << PB5)
#define Read_24L01_MOSI PINB & (1 << PB5)
//#define NRF24L01_SCK PB7 //输出1
#define Hign_24L01_SCK PORTB |= (1 << PB7)
#define Low_24L01_SCK PORTB &= ~(1 << PB7)
#define Read_24L01_SCK PINB & (1 << PB7);
//#define NRF24L01_CSN PB4 //输出1
#define Low_24L01_CSN PORTB &= ~(1 << PB4)
#define Hign_24L01_CSN PORTB |= (1 << PB4)
//#define NRF24L01_CE PB3 //输出1
#define Hign_24L01_CE PORTB |= (1 << PB3)
#define Low_24L01_CE PORTB &= ~(1 << PB3)
#define Read_24L01_CE PINB & (1 << PB3)
//*********************************************NRF24L01*************************************
#define TX_ADR_WIDTH 5 // 发送地址长度,最大长度为5 5*8=40 bit
#define RX_ADR_WIDTH 5 // 接收地址长度
#define TX_PLOAD_WIDTH 32 // 发送字节长度,
#define RX_PLOAD_WIDTH 32 // 接收字节长度
uchar TX_ADDRESS[TX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01}; //发送地址
uchar RX_ADDRESS[RX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01}; //接收地址
//***************************************NRF24L01寄存器指令*******************************************************
#define READ_REG 0x00 // 读寄存器指令
#define WRITE_REG 0x20 // 写寄存器指令
#define RD_RX_PLOAD 0x61 // 读取接收数据指令
#define WR_TX_PLOAD 0xA0 // 写待发数据指令
#define FLUSH_TX 0xE1 // 冲洗发送 FIFO指令
#define FLUSH_RX 0xE2 // 冲洗接收 FIFO指令
#define REUSE_TX_PL 0xE3 // 定义重复装载数据指令
#define NOP 0xFF // 保留
//*************************************SPI(nRF24L01)寄存器地址****************************************************
#define CONFIG 0x00 // 配置收发状态,CRC校验模式以及收发状态响应方式
#define EN_AA 0x01 // 自动应答功能设置
#define EN_RXADDR 0x02 // 可用信道设置
#define SETUP_AW 0x03 // 收发地址宽度设置
#define SETUP_RETR 0x04 // 自动重发功能设置
#define RF_CH 0x05 // 工作频率设置
#define RF_SETUP 0x06 // 发射速率、功耗功能设置
#define STATUS 0x07 // 状态寄存器
#define OBSERVE_TX 0x08 // 发送监测功能
#define CD 0x09 // 地址检测
#define RX_ADDR_P0 0x0A // 频道0接收数据地址
#define RX_ADDR_P1 0x0B // 频道1接收数据地址
#define RX_ADDR_P2 0x0C // 频道2接收数据地址
#define RX_ADDR_P3 0x0D // 频道3接收数据地址
#define RX_ADDR_P4 0x0E // 频道4接收数据地址
#define RX_ADDR_P5 0x0F // 频道5接收数据地址
#define TX_ADDR 0x10 // 发送地址寄存器
#define RX_PW_P0 0x11 // 接收频道0接收数据长度
#define RX_PW_P1 0x12 // 接收频道0接收数据长度
#define RX_PW_P2 0x13 // 接收频道0接收数据长度
#define RX_PW_P3 0x14 // 接收频道0接收数据长度
#define RX_PW_P4 0x15 // 接收频道0接收数据长度
#define RX_PW_P5 0x16 // 接收频道0接收数据长度
#define FIFO_STATUS 0x17 // FIFO栈入栈出状态寄存器设置
//******* void spi_init() 初始化SPI
void spi_init()
Hign_24L01_CSN;
DDR_SPI = (1<<DD_MOSI)|(1<<DD_SCK)|(1<<DD_SS)|(1 << CE);//设置MOSI,SCK,SS.CE 为OUTPUT,其它为INPUT
DDR_SPI&=~((1<<DD_MISO)|(1<<IRQ));
SPCR=(1<<SPE)|(1<<MSTR)|(1<<SPR0);//使能SPI接口,主机模式,MSB低位在前,模式0,16分频,SPI时钟1MHZ
SPSR=0;
//******* uchar SPI_RW(uchar date) 读写SPI
SPDR=date;
while(!(SPSR&(1<<SPIF)));
return SPDR;
//*******uchar SPI_Read(uchar reg) 读24L01寄存器
uchar reg_val;
Low_24L01_CSN;
SPI_RW(reg);
reg_val = SPI_RW(0);
Hign_24L01_CSN;
return(reg_val);
//******* uchar SPI_RW_Reg(uchar reg, uchar value)
// 写24L01寄存器
uchar status;
Low_24L01_CSN;
status = SPI_RW(reg);
SPI_RW(value);
Hign_24L01_CSN;
return(status);
//******* uchar SPI_Read_Buf(uchar reg, uchar *pBuf, uchar bites)
// 读24L01 寄存器BUFF
uint status1,uchar_ctr;
Low_24L01_CSN;
status1 = SPI_RW(reg);
for(uchar_ctr=0;uchar_ctr
pBuf[uchar_ctr] = SPI_RW(0);
Hign_24L01_CSN;
return(status1);
//******* uchar SPI_Write_Buf(uchar reg, uchar *pBuf, uchar bites)
// 写24L01 寄存器BUFF
uchar status1,uchar_ctr;
Low_24L01_CSN; //SPI使能
for(uchar_ctr=0; uchar_ctr
SPI_RW(*pBuf++);
Hign_24L01_CSN; //关闭SPI
return(status1); //
//******* void SetRX_Mode(void)
// 接收模式设置
Low_24L01_CE;
SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, RX_ADDRESS, RX_ADR_WIDTH); //写接收地址
SPI_RW_Reg(WRITE_REG + EN_AA, 0x01); //0通道自动应答
SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01); //数据通道0
SPI_RW_Reg(WRITE_REG + RF_CH,0); //射频通道
SPI_RW_Reg(WRITE_REG + RX_PW_P0, RX_PLOAD_WIDTH);//写通道0 接受数据长度
SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07); //0db 1M
SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); //接收模式
Hign_24L01_CE; //开始接收
delayus(200);//注意不能太小
//******* uchar nRF24L01_RxPacket(uchar* rx_buf)
// 接收数据包
uchar sta,flag=0;
sta=SPI_Read(STATUS); // 读取状态寄存其来判断数据接收状况
if(sta&0x40) // 判断是否接收到数据RX_DR==1?
Low_24L01_CE; // StandBy I模式
SPI_Read_Buf(RD_RX_PLOAD,rx_buf,TX_PLOAD_WIDTH);// read receive payload from RX_FIFO buffer
flag =1; //读取数据完成标志
SPI_RW_Reg(WRITE_REG+STATUS,sta); //接收到数据后RX_DR,TX_DS,MAX_PT都置高为1,通过写1来清楚中断标志
return (flag);
//******* void nRF24L01_TxPacket(uchar * tx_buf)
// 发送数据包
void nRF24L01_TxPacket( uchar * tx_buf)
uchar sta=0;
uchar flag=0;
Low_24L01_CE; //StandBy I模式
SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH);
SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // 装载接收端地址
SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH); // 装载数据
SPI_RW_Reg(WRITE_REG + SETUP_RETR, 0x1f); //500+86us
SPI_RW_Reg(WRITE_REG + RF_CH, 0); //
SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e); // IRQ收发完成中断响应,16位CRC,主发送
delayms(2);
Hign_24L01_CE; //置高CE,激发数据发送
delayus(10);
Low_24L01_CE;
void init_NRF24L01(void)
spi_init();
Low_24L01_CE; // 空闲模式
Hign_24L01_CSN; // SPI 关闭
Low_24L01_SCK; // 关闭时钟
永不止步步 发表于12-20 10:45 浏览65535次
