PID代码开源
检查了下代码。。memset(S->in_e, 0, 3u * sizeof(unsigned short int));改成这样更好些。。
void *
memset (void *s, int c, unsigned n)
    /* Not optimized, but very portable */
    unsigned char *sp = (unsigned char *)s;
    if ((s != NULL) && (n > 0))
        while (n--)
*sp++ = (unsigned char)c;
    return s;
speed = lptmr_get();
    lptmr_clean();
    __push_pid_para_(&PID_change,need_speed - speed);
    PWM = __s16_GetPluse_(&PID_change);
    if( PWM > 0 )
        PWMisZheng = 1;
        vMoto
补充内容 (2014-7-7 22:25):
rBackChange(0);
        vMotorForChange(__ABS(PWM));
    else
        PWMisZheng = 2;
        vMotorForChange(0);
        vMotorBackChange(__ABS(PWM));
代码地址:http://www.eeskill.com/resource/index/id/14142
永不止步步 发表于11-14 10:01 浏览65535次
